  3. Changing amount of rows and columns in a selected contact...
  • Replies 13
  • Subscribers 152
  • Views 24376
Changing amount of rows and columns in a selected contact cell
blankman
blankman over 15 years ago
Hi all, Im trying to add bind keys to increment and decrement the amount of rows and columns in a selected contact cell.
Im using...
procedure(BSchangeVia2x1()
foreach(fig geGetSelSet()
  when(fig~>objType=="inst"
      propValue = car(fig~>prop~>value)
      fig~>prop~>value=propValue+1
hiSetBindKey("Layout" "Alt<key>KP_Add" "BSchangeVia2x1()")
However this increments both row and column values. Is there a way to increment only the row value and leave the column value as is?
Cheers,
Brian.
  • dmay
    dmay over 15 years ago
    If you turn on every item in your log filter (CIW->Options->Log Filter), then when you make an update to a form item, you will see what happened in your CIW. You can then put this in a bindkey.
    Example:
    Opening the create via form: leHiCreateVia()
    Changing the rows field: le0ViaForm->viaSingleModeScrollView->parameters->page1->rows->value= 3
    Bindkey to update form: hiSetBindKey("Layout" "<Key>5" "le0ViaForm->viaSingleModeScrollView->parameters->page1->rows->value=5")
    This isn't the most ideal way to do things, but may suit your needs for now.
    Derek
  • vmartins
    vmartins over 15 years ago
     Hi, thanks for the help and yes this is almost enough, but only work for vias form.
    what I wanted is to use in any form that haves rows and columns option field, I tried to use hiGetCurrentForm and hiChangeFormCallback and then try to over right the value... but I still don't have the code knowledge to do this....
    I just got a cadence Skill 400 page book so now I just need the time to read it..
    but thanks a lot for the help
    best regards
  • frogconsultant
    frogconsultant over 14 years ago
    Hi All,
    I am exactly in the same problem but I am using 6.1 environment and the vias are completly managed differently as everyone found out.
    Does someone could point me to a document related to the new command to control contact cell?
    Does someone know the command to access row or column?
    Thanks in advance,
    Fabian
