  3. Changing amount of rows and columns in a selected contact...
  • Replies 13
  • Subscribers 152
  • Views 24376
Changing amount of rows and columns in a selected contact cell
blankman
blankman over 15 years ago
Hi all, Im trying to add bind keys to increment and decrement the amount of rows and columns in a selected contact cell.
Im using...
procedure(BSchangeVia2x1()
foreach(fig geGetSelSet()
  when(fig~>objType=="inst"
      propValue = car(fig~>prop~>value)
      fig~>prop~>value=propValue+1
hiSetBindKey("Layout" "Alt<key>KP_Add" "BSchangeVia2x1()")
However this increments both row and column values. Is there a way to increment only the row value and leave the column value as is?
Cheers,
Brian.
  • dmay
    dmay over 15 years ago
    Brian,
    Take a look at the prop~>name values. You are incrementing every property by one. Since there are both row and column properties, you will therefore increment both. It is also possible that there are other properties that are not integers and will cause your code to fail. You can actually increment the value of the row and column settings by directly accessing the property by name.
    fig~>row =  fig~>row + 1  (assuming row is the property name)
    Also, in your code you are getting the prop value using:
    You are using "car" because fig~>prop is a list and therfore fig~>prop~>value is a list. However, you are incrementing ALL props with this since fig~>prop is a list:
    fig~>prop~>value = propValue + 1
    If you just want to change the first prop:
    car(fig~>prop~>value) = propValue + 1
    This is more consistent with the way you retrieved the value in the first place. However, the property list is not always going to be in the order you expect. You should look at the property name before you adjust the value either by going to the known property directly as I demonstrated (fig~>row), or by checking the name like this:
    foreach(prop fig~>prop
      when(fig~>prop~>name=="row"
        fig~>prop~>value = fig~>prop~>value + 1
    Derek
    Or you could use dbFindProp or dbGetPropByName instead of that last foreach:
    prop=dbFindProp(fig "row")
    prop~>value=prop~>value+1
    Andrew (sorry, not very responsive at the moment; too much time needed for the day job)
  • blankman
    Thanks lads, that did the trick. I appreciate the help!
  • sudheer g
    sudheer g over 15 years ago
    hello guys,
    can we use the car(.....) function on the left hand side...
    ex:
    car(fig~>prop~>value)=propvalue+1;
    is it possible?
    i think not...
    if it is impossible to use car(....) on the left hand side how can we modify only rows in that?
  • sudheer g
     hey try this
     procedure(viarowincrement()
    fig=geGetSelSet()
    rov=fig~>row
    fig~>row=rov+1
    );when
    );foreach
    );procedure
    hiSetBindKey("Layout" "Alt Shift<key>=" "viarowincrement()")
    procedure(viarowdecrement()
    fig=geGetSelSet()
    rov=fig~>row
    if(rov>2
    fig~>row=rov-1
    );if
    );when
    );foreach
    );procedure
    hiSetBindKey("Layout" "Alt Shift<key>-" "viarowdecrement()")
    procedure(viacolumnincrement()
    fig=geGetSelSet()
    colum=fig~>column
    fig~>column=colum+1
    );when
    );foreach
    );procedure
    hiSetBindKey("Layout" "Ctrl Shift<key>=" "viacolumnincrement()")
    procedure(viacolumndecrement()
    fig=geGetSelSet()
    colum=fig~>column
    if(colum>2
    fig~>column=colum-1
    );if
    );when
    );foreach
    );procedure
    hiSetBindKey("Layout" "Ctrl Shift<key>-" "viacolumndecrement()")
  • blankman
    Heres the code I ended up using. I noticed I had to delete the property once values had reached below 2 columns as it output strange behaviour for negative row and column values..
    ;Procedures to change already placed contact -> column/row
    procedure(BSchangeViaHorizInc()
                  prop=dbFindProp(fig "column")
                if( prop != nil
                    then fig~>column = fig~>column + 1
                    else dbCreateProp(fig "column" "int" 2)
    hiSetBindKey("Layout" "Alt<key>KP_Multiply" "BSchangeViaHorizInc()")
    procedure(BSchangeViaHorizDec()
                if( prop != nil
                    then     if( fig~>column >= 3
                            then fig~>column = fig~>column - 1
                            else dbDeletePropByName(fig "column")
                    else    nil
    hiSetBindKey("Layout" "Alt<key>KP_Divide" "BSchangeViaHorizDec()")
    procedure(BSchangeViaVertInc()
                if( prop != nil
                    then fig~>row = fig~>row + 1
                    else dbCreateProp(fig "row" "int" 2)
    hiSetBindKey("Layout" "Alt<key>KP_Add" "BSchangeViaVertInc()")
    procedure(BSchangeViaVertDec()
                if( prop != nil
                    then     if( fig~>row >= 3
                            then fig~>row = fig~>row - 1
                            else dbDeletePropByName(fig "row")
                    else    nil
    hiSetBindKey("Layout" "Alt<key>KP_Subtract" "BSchangeViaVertDec()")
    hiSetBindKey("Layout" "Shift Alt<key>KP_Subtract" "BSchangeVia2x1()")
    procedure(BSchangeVia1x2()
    hiSetBindKey("Layout" "Shift Alt<key>KP_Add" "BSchangeVia1x2()")
  • blankman
    And also the via justification.....
    ;Procedures to change already placed contact -> justification
    procedure(BSchangeViaLeft()
                dbDeletePropByName(fig "xBias")
                dbCreateProp(fig "xBias" "string" "right")
                dbDeletePropByName(fig "yBias")
    hiSetBindKey("Layout" "Alt<key>KP_Home" "BSchangeViaLeft()")
    procedure(BSchangeViaRight()
                dbCreateProp(fig "xBias" "string" "left")
    hiSetBindKey("Layout" "Alt<key>KP_Page_Up" "BSchangeViaRight()")
    procedure(BSchangeViaUp()
                dbCreateProp(fig "yBias" "string" "bottom")
    hiSetBindKey("Layout" "Alt<key>KP_Up" "BSchangeViaUp()")
    procedure(BSchangeViaDown()
                dbCreateProp(fig "yBias" "string" "top")
    hiSetBindKey("Layout" "Alt<key>KP_Begin" "BSchangeViaDown()")
    procedure(BSchangeViaCenter()
    hiSetBindKey("Layout" "Alt<key>KP_Right" "BSchangeViaCenter()")
  • vmartins
    vmartins over 15 years ago
    Hi to all, great job but I dont know what cadence version was used but in version 6
    is not working....
    it gives back this message:
    (db:0x17910412)
     and nothing happen to the via.
    keep up with the good feature.
    Vasco
    Vasco,
    Looking at the code, it was written for IC5141 (or earlier) - essentially it follows the CDB model for vias (which are just instances). In OpenAccess, vias are separate objects - and the code checks that they are instances. It's not as simple as checking that the selected objects are vias - the property names are different, and the dbFindProp would fail. Needs a fairly hefty overhaul (don't have time to do this myself, unfortunately).
  • vmartins
    Hi, thanks for the reply...
    I see, update changes... anyway I didn't need a so complex code, just a way to input variables in the a field inside the option form.
     But thanks for the help anyway, maybe some other time.
    best regards and keep up with the good work
    Vasco
