  3. Skill code to perform cut,copy paste operations( as in MS...
  • Subscribers 152
  • Views 3073
Skill code to perform cut,copy paste operations( as in MS execl)
deepak1947
deepak1947 over 15 years ago
Hello, I was trying to build a skill code which could do the cut,copy, paste operations of any selected layer(s)/instances(s) from one cell view to other or from one hierarchy to other. The result would be copying/moving in the exact x,y location of selected layer(s)/instances(s) from one cell view to other or from one hierarchy to other. I tried to use the leYankFigs() and lePasteFigs() for this, but this code only copies(not moves) any selected layer(s)/instances(s) from one cell view to other. Also is acts as leYank() function wherein it copies all the layers from a selected area. The code I tried is: hiSetBindKey("Layout" "Ctrlc" "mscopy()") procedure(mscopy() prog((cv selectedset) cv=geGetEditCellView() selectedset=geGetSelectedSet() points=selectedset~>bBox temp = xCoord( lowerLeft( points )) temp1 = yCoord( lowerLeft( points )) llx = car(temp) lly = cadr(temp) urx = car(temp1) ury = cadr(temp1) lrx = urx lry = lly ulx = llx uly = ury ;leYankFigs( cv list( 0:0 10:0 10:10 0:10 ) 2 ) leYankFigs( cv list( llx:lly lrx:lry urx:ury ulx:uly ) 2) );prog );procedure hiSetBindKey("Layout" "Ctrlv" "mspaste()") procedure(mspaste() prog((cv selectedset) cv=geGetEditCellView() lePasteFigs( cv llx:lly) );prog );procedure
  • Austin CAD Guy
    Austin CAD Guy over 15 years ago
     Both dbMoveFig and dbCopyFig have a cellView argument which allows you to move/copy shapes from one cellView to another. Since these work on on shape at a time, you have to put them in a loop. The transform can be used to move/rotate the shapes in the new cellView:
    foreach( shape listOfShapeToMove
      dbMoveFig( shape newCellView [(0:0 "R90)] ) ;; Leave out the transform if you want things to go in the same place.
    Ted
  • deepak1947
    Thanks Ted!.
     I just modified the code a little for my convienence :
    hiSetBindKey("Layout" "Ctrl<Key>c" "mscopy()")
    hiSetBindKey("Layout" "Ctrl<Key>v" "mspaste()")
    procedure(mscopy()
    src=geGetSelectedSet()
    procedure(mspaste()
    prog((cv2)
    cv2=geGetEditCellView()
    foreach( shape src
      dbCopyFig(shape  cv2 )
    );procedure
    );prog
    hiSetBindKey("Layout" "Ctrl<Key>x" "mscut()")
    hiSetBindKey("Layout" "Ctrl<Key>m" "msmove()")
    procedure(mscut()
    procedure(msmove()
    prog((cv2)
    foreach( shape src
      dbMoveFig(shape  cv2 )
    );procedure
    );prog
