  3. Preventing a form from unmapping till the user wishes
  • Subscribers 152
  • Views 16521
mana
mana over 15 years ago
 Hi
Iam designing a GUI for an application. I have used the hiCreateAppForm function in it to create a  form. By default, the form gets unmapped once the user presses OK. In case the user again wants to give inputs with minor changes in the fields, he has to fill the entire form all over again. So i wanted to keep some option to keep the form mapped on screen with all the fields having previous values filled in them, till the user himself gives instruction to fill a fresh form. I was looking for some argument in the hicreateAppForm function or a seperate function to enable such a thing.
So if I may get some suggestions on the same.
  • dmay
    dmay over 15 years ago
    Here are two things you can do:
    1. Add an Apply button to your form so that the form is not dismissed:
        ?buttonLayout 'OKCancelApply
    2. Define your form as a global variable and if the form is already bound, just display the form, do not recreate it:
    unless(boundp('_MY_FORM)
        hiCreateAppForm(?name '_MY_FORM
    hiDisplayForm(_MY_FORM)
    Derek
  • mana
     Well i tried using the function hiGetCurrentForm()
    hiDisplayForm(hiGetCurrentForm()) - this again displays the form with the filled in fields, after the code is executed. But if i try changing the field infos and executing the code again by pressing OK in the same form it doesnt work! It states that the data is incompatible with the data specification format.
  • mana
     @derek
    I have incorporated apply button in my form, m getting the same error as mentioned in the previous post, on pressing the apply button.
    *Error* get/getq: first arg must be either symbol, list, defstruct or user type - 2
     The above error is flashed whenever any of the field is changed and apply button is pressed after the code has been executed once. The apply button works fine when the code is executed for the first time.
    Thanks alot for ur inputs! :)
  • Austin CAD Guy
    Austin CAD Guy over 15 years ago
     Can you post the code?
  • dmay
    Try enabling some debugging information so that you get more than a one line error message:
    sstatus(stacktrace 10)
    sstatus(stacktraceDump t)
    sstatus(traceArgs t)
    Derek
    Doing hiDisplayForm(hiGetCurrentForm()) doesn't make a massive amount of sense, since the form is unlikely to be current unless it's currently displayed (in which case displaying it seems rather redundant). Instead you should give the variable the form data structure is stored in (i.e. the ?name arg to hiCreateAppForm).
    As Ted pointed out, seeing the code and the exact error messages would really help. Everything is a bit vague at the moment!
