  3. Creation of custom view types in IC6
  • Views 16243
tyanata
tyanata over 15 years ago
 Can anyone say is there some difference in creation of custom view types in IC6 compared to IC5.
In out IC5 design environment we use several custom viewtypes, registered with corresponding .reg files in $CDSHOME/share/cdssetup/registry/data/ folder.
So I just copied these .reg files in IC6_install_path//share/cdssetup/registry/data/
After that when I opened in IC6 create new  cellview menu these viewtypes appear in the list. But after that when try to create such cellview the routine crashes.
    It should work the same way. Do you really mean that it "crashes" (i.e. does virtuoso abort), or do you mean that you get a SKILL error?
    If it crashes (i.e. virtuoso exits) you should report it to customer support. If it gives a SKILL error, you might want to post the code here together with the error message and we can take a look (or report to customer support).
  • tyanata
    In fact cadence not crashes but error message appear in IC6. The same routine works well in IC5.
    Brief description: this custom view type is called xls and in fact is Excel file attaching as cellview. You can attach already existing xls file or to create new one on basis of existing template file.
    First I post the text of file called xls.reg which is placed in  $CDSHOME/share/cdssetup/registry/data/
    File Name:    :    xls.reg
    DataFormat ExcelSheet {
      Pattern = *.xls;
      Default_Editor = ExcelSheet ;
     dfII_ViewType = xls;
     Co_Managed= *.xls master.tag;
    Tool ExcelSheet{
    Tool_Alias = oocalc;
    Tool oocalc {}
    ViewAlias {
      xls=ExcelSheet;
    After that is text of file called xls.il which is in fact the routine of creating xls view:
    /* xls.il
    ;Create the initial panel form
    l_sep0 = list(
                 hiCreateSeparatorField(
                   ?name 'sep0
               ) 1:5 400:0)
    l_sep1 = list(
                   ?name 'sep1
               ) 399:6 70:1)
    l_sep2 = list(
                   ?name 'sep2
               ) 0:75 400:0)
    l_sep3 = list(
                   ?name 'sep3
               ) 0:6 69:1)
    l_radio1 = list(trXlsFileSelect = hiCreateRadioField(
        ?name        'trXlsFileSelect
        ?prompt     ""
        ?choices    list("Create new *.XLS file" "Select existing *.XLS file")
        ?defValue    "Create new *.XLS file"
        ?itemsPerRow    1
        ) 0:20 400:20)
    l_string1 = list(trXlsFileNameField = hiCreateStringField(
        ?name        'trXlsFileNameField
        ?invisible    t
        ?defValue    "NOFILE"
        ) 0:50 400:10)
    trXlsSelectForm = hiCreateAppForm(
        ?name         'trXlsSelectForm
        ?formTitle    "Chose creation mode"
        ?callback    '("XlsSelectFormCB(hiGetCurrentForm() )")
        ?fields        list(l_sep0 l_sep1 l_sep2 l_sep3 l_radio1 l_string1)
        ?buttonLayout    'OKCancel
        ;?unmapAfterCB    t
    procedure( XlsSelectFormCB(theForm)
    prog((file_path file_extension file retdia fchoice)
    retdia = t
    file_path=""
    file_extension=""
    fchoice = theForm->trXlsFileSelect->value
    case( fchoice
    ( "Create new *.XLS file"
    ; put here some excel file
    file_path = ".../template.xls"
    theForm->trXlsFileNameField->value = file_path
    retdia = t
    );Create new *.XLS file
    ("Select existing *.XLS file"
    while(!isFile(file_path) || (file_extension != "xls")
    theForm->trXlsFileNameField->value = "*.xls"
    ddsFileBrowseCB(theForm 'trXlsFileNameField  "*.xls")
    file_path = theForm->trXlsFileNameField->value
    if(!isFile(file_path) then
    warnText = sprintf(nil "File doesn't exist:\nPress YES to try again")
    ;display warning box
    retdia = hiDisplayAppDBox(
        ?name 'xx
        ?dboxBanner " "
        ?dboxText warnText
        ?buttonLayout 'YesNo
    ;file exists, but extension doesn't match program_file_extension
    else
    ;get file
    file = car(last(parseString(file_path "/")))
    ;get file extension
    file_extension = car(last(parseString(file ".")))
    ;println(file_extension)
    if(file_extension != "xls" then
    warnText = sprintf(nil "%s is not a XLS file:\nPress YES to try again" file )
    retdia = hiDisplayAppDBox(?name 'xx
    ?dboxBanner " "
    ?dboxText warnText
    ) ; if
    ) ;if
    ;user gives up - then return NOFILE
    when(!retdia
    file_path = "NOFILE"
    return(nil)
    );when
    ); while
    );Select existing *.XLS file
    );case
    ;println(file_path)
    return(t)
    );prog
    );SelectFormCB
    procedure( openXlsDataTrigger(argList)
    prog(( cellName file libName objId tmplFile viewFileName viewName viewType cmd)
      cellName = argList->cellName
      libName = argList->libName
      viewName = argList->viewName
      viewType = argList->viewType
      mode = argList->accessMode
      viewFileName = ddMapGetViewTypeFileName( viewType )
    case( mode
          ("w" ; Create the XLS cellView if not exists or re-write
    tmplFile = "NOFILE"
    hiFormDefaults(trXlsSelectForm)
    while(!isFile(tmplFile)
    hiDisplayForm( trXlsSelectForm )
    tmplFile = trXlsSelectForm->trXlsFileNameField->value
    ;when user gives up
    when(tmplFile == "NOFILE"
    ;delete the cell
    ;if open for read, it exists
    objId=ddGetObj(libName cellName viewName viewFileName nil "r")
    if(!objId then
    ;get object Id
    objId = ddGetObj(libName )
    if((length(dbAllCellViews(objId cellName)) <= 1) &&  member(viewName dbAllCellViews(objId cellName)) then
    cmd=sprintf(nil "\\rm -Rf %s" ddGetObj(libName cellName)~>writePath); delete the whole cell if it containf only XLS
    else
    cmd=sprintf(nil "\\rm -Rf %s" ddGetObj(libName cellName viewName)~>writePath); delete XLS view only
    ;delete object
    ;println(cmd) - tracking
    unless(system(cmd)
    error(" ERROR - command failed: %s \n" cmd)
    ) ; unless
    ) ; if
    return(nil)
    );when
    );while
    objId = ddGetObj(libName cellName viewName)
    unless(objId~>isWritable
    ;checkout call
    ddAutoCheckout(objId)
    ;checkout failed, error out
    error("View could not be opened for edit.")
    ) ; unless
    ;delete object
    cmd=sprintf(nil "\\rm -rf %s" objId~>writePath)
    unless(system(cmd)
    ) ; unless
     file = strcat(libName "_" cellName "_" viewName ".xls")
     printf(file)
     objId = ddGetObj(libName cellName viewName file nil "w" )
    ;get file path
    file_path = ddGetObjWritePath(objId)
    ;copy the file to the cell view location
    cmd=sprintf(nil "\\cp %s %s" tmplFile file_path)
    unless(system(cmd)
    ) ; unless
    system(sprintf(nil "chmod +w %s" file_path))
    file = ddGetObjWritePath( objId )
    cmd = sprintf( nil "ooffice -nologo %s  &" file )
    );w
        ("a" ;open existing cell wor write
        if( objId = ddGetObj( libName cellName viewName viewFileName nil "r" ); if exists - just open it
        then
        else
            ;display error message
            ?dboxBanner " "
            ?dboxText "Error: maybe file doesn't exist or failed"
            ?buttonLayout 'CloseHelp
            return(nil);exit
        );if
    );a
        ("r" ;read-only
        then
            cmd = sprintf( nil "ooffice -nologo -view %s  &" file );open in viewer mode
        else
            ?dboxBanner " "
            return(nil);exit
        );if
    );r
    );case
      ; Start OpenOffice
      system(cmd)
      return(t)
      ); prog
    );procedure
    ; Dummy trigger functions
    procedure( CCSxlsAppTrig(argL) t )
    procedure( CCSxlsEnableTrig(@optional argL) t )
    procedure( CCSxlsRegister()
      deRegApp(
        ?appName "oocalc"
        ?appTrigger 'CCSxlsAppTrig ; Dummy function
        ?dataTrigger 'openXlsDataTrigger
        ?enableTrigger 'CCSxlsEnableTrig ; Dummy function
        ?viewType "xls"
        ?widgetType "none"
    ; Register the triggers
    unless(deViewTypeIsRegistered("xls")
    CCSxlsRegister()
    Be aware that following lines have to be customized for your case:
    Here you just have to create one file called template.xls and to enter its path insted of  .../template.xls.
    Here is the error message which I receive in IC6:
     *Error* View could not be opened for edit.
    *WARNING* (DEBASE-102079): A SKILL error occurred in function openXlsDataTrigger
    Best regards,
    tyanta
  • tyanata
    Additional information about the routines in xls.il. They are based on the routines in Solution ID:    1836295 .
    Only difference is that we added possiblity file with name different from "template" to be used for cellview xls.
