  3. How to use skill to change PCell parameter like using Edit...
  • Replies 9
  • Subscribers 152
  • Views 22485
How to use skill to change PCell parameter like using Edit Instance Properties to change parameter ?
Charley Chen
Charley Chen over 15 years ago
Hi All,
When using Pcell , press  q to use "Edit Instance Properties" to change parameter (e.g.  length) ,
in cdf  , it has callback ,  everything is right according to callback function . Different length has it different result in Pcell.
Now I have many Pcells needs to changed  parameter - length (from 2um to 4um) by  "Edit Instance Properties" ,
Is there any approach to do that ? (Not manual use "Edit Instance Properties" to change each Pcell's parameter ?
After changing parameter - length , its result should same as using "Edit Instance Properties" .
Thank you.
Charley
  • StefanSL
    StefanSL over 15 years ago
     Hi Charley,
    what about the following piece of code:
    tc=geGetEditCellView()
    foreach(ti tc~>instances if(ti~>PCLENGTH then ti~>PCLENGTH = 4))
    i check for existence of the parameter PCLENGTH to avoid to add this as property to
    other cells; perhaps you need to modify the if-condition to be sure only to modify the
    correct set of cells.
    hope this helps
    regards
    Stefan
  • Charley Chen
    Hi Stefan ,
     Does it do any CDF callback if length has callback function ?
    Thank you,
    Charley
  • StefanSL
     Hi Charley,
    i'm not really sure about that, but the cdfuser-manual states
    "Callbacks are triggered whenever a change is made to the parameter value, even if the
    change is caused by loading a default value."
    This sounds good, but you should check if this applies to your special application too.
    Kind regards
    Stefan
    Take a look at solution 11018344 - this has code to call CDF callbacks procedurally.
  • Charley Chen
    Andrew,
    Thank you, but the link is not exist.
    Charley
  • Austin CAD Guy
    Austin CAD Guy over 15 years ago
    CDF callbacks are only executed during the interactive editing of the parameters through the Edit Property form or the Edit Property Assistant (IC6.1). If you are changing them programmatically, you have to execute the callback. Here is a way to do it:
    ;; Get the instance
    inst = car(selectedSet())
    ;; Instance CDF
    cdfgData = cdfGetInstCDF(inst)
    inst->length = newLength
    param = cdfFindParamByName( cdfgData "length")
    when(param->callback
      evalstring(param->callback)
    Ted (this line is not part of the code)
  • StefanSL
     Hi Charley,
    there's a small (but  nevertheless vital) error in Andrews link:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNu mber=11018344
    remove the space within "Nu mber", then it works fine...
    regards, have a nice weekend
    Stefan
    Apologies - cut and paste error. Did it in too much of a hurry - thanks Stefan for fixing it!
  • Charley Chen
    Ted,
    It works , thank you.
    Charley
