  3. Hierarchy function for the instantiated symbol
  • Subscribers 152
  • Views 15786
skillseeker
skillseeker over 15 years ago
I am parsing a schematic to find the information of the instantiated symbols for the design. I would like to know if there is a function in skill that will let me know if any symbol instantiated in the schematic has hierachy.(like a schematic view underneath the symbol and soon). Is there a straightforward method to do implement this functionality.
Thanks in advance
    One way is to use dbGetAnyInstSwitchMaster - you give it a switch list of views to look at to see if there's a schematic.  Potentially it's more complex than this - all depends on whether you want to only work with switch lists or whether you expect it to work on a schematic under a config (i.e from the hierarchy editor).
  • skillseeker
    Thanks Bracknell. I really am not interested in descending into the hierarchical instance but rather build a hierarchy tree from my top-level instance. I was wondering if skill offered any function to dump out all the instances which have schematic views and their children have schematics and so on.. I got around this problem by implementing a looping structure on each instantiated symbol from my top view.
    Maybe take a look at this to get some ideas:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nVxnEAE&pageName=ArticleContent
  • VLSIgirl
    VLSIgirl over 15 years ago
    Hello Skillseeker,
    I am new to skill and trying to descend through various levels of schematics. Could you give me an idea as to how you implemented the looping structure on each instantiated symbol form the top view?
