  3. Descending into a cell - skill function
  • Replies 18
  • Views 12553
swdesigner
swdesigner over 15 years ago
I currently bind my key to call schHiDescend, and work on the form.
Is there a way to bypass the form and call a function with the name of an instance in the current cellview to descend into it?
  • swdesigner
    Thanks Andrew,
    I verified this works. I guess the documentation needs to be updated then...
  • swdesigner
    Okay, I have basic functionality, but there's still work to do... When I'm browsing a configuration, the schHiDescend form gives me options with the default being what is set in the configuration (hierarchy editor) How can I set my viewNameList to be that...? Any clues would be great. Thanks!
    You could use this code:
    /* abWhichView.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Oct 03, 2005
    Modified
    By
    Function which can be used as a label on a symbol, to say
    which view is being used in a config.
    Create an ILLabel, with value "abWhichView()"
    SCCS Info: @(#) abWhichView.il 10/03/05.15:07:34 1.1
    *                   (abWhichView [instId] [wid])                   *
    *     Returns the name of the view bound in the config, or nil     *
    * if there is no config. instId defaults to ilInst - the currently *
    *     drawn instrane, and wid defaults to the current window.      *
    (procedure (abWhichView @optional (instId ilInst) (wid (hiGetCurrentWindow)))
      (let (pathVector bindInfo)
           (setq pathVector (deGetVector wid))
           (when pathVector
                 (setq bindInfo
                       (hdbBind
                        pathVector
                        (dbGetq instId libName)
                        (dbGetq instId cellName)
                        (dbGetq instId viewName)
                        (dbGetq instId name)
                        nil nil nil
                 ; The third entry in the list is the view used
                 (caddr bindInfo)
                 ) ; when
           ) ; let
      ) ; procedure
  • swdesigner
    Hello Andrew,
             This still doesn't do it. I think what I need already exists.. but I don't know how to get my hands on it.. Let me explain..
     The code you provided gives me the view being used if I'm viewing a config. If not, pathVector doesn't exist. In that case what do I do?
    However, when I use the descend function (default bindkey is 'e'), Cadence already knows what order to give me the views in... if it's a config, it puts the view being used first in the drop-down menu for view.. If it's not a config, and a schematic view exists, it gives me that on top.
    So, the work is already done. How can I get "that" view (that Cadence puts at the top of the list when using the descend dialog) without using the form, through skill.
    Why do I want to bypass the form?
    Because there is a bug that causes a remnant of that form to remain after bindkey based interaction... some of the time.. and it's an annoyance...
    Thanks!
  • dmay
    dmay over 15 years ago
    Will geSwitch do what you want?
     geSwitch(
    w_windowId
    t_accessMode
    d_instId
    x_iteration
    x_row
    x_col
    [ g_cancel ]
    => t / nil
    Switches into an instance.
    w_windowId->viewNameList is used as a switch for the instance. w_windowId must be a valid Graphics Editor window with at least one stack element, and d_instId must be an instance in the edit cellview in w_windowId.
    Derek
  • swdesigner
    Okay, with this and Andrew's code, I have something that works..  and then some!!
    (let (n instId pathVector bindInfo wid myFileSpec)
          (when (instId = car(geGetSelSet() ) )
          n = instId~>name;
          rexCompile(":[0-9]>");
          n = rexReplace(n ">" 1);     to handle arrayed instances
               wid = hiGetCurrentWindow()
              (setq pathVector (deGetVector wid) )
             if( pathVector
                 then
                       (setq bindInfo
                              (hdbBind
                                  pathVector
                                          nil nil nil
                              ) ; setq
                     myFileSpec = list( nil 'instanceName n 'viewNameList caddr(bindInfo) );
                     dePush("myFileSpec wid "read");
              else
                    geSwitch( wid "r" instId 0 0 0)
             ) ; if
         ) ; when
    ) ; let
    Thanks guys!!
  • swdesigner
    Bottom line, this code doesn't work reliably. My EDA folks suggest that
    is the problem - pathVector obtained from the current window is not reliable for binding information. The suggestion was to consider the example in $CDSHOME/tools/hdb/examples/hdbTraverse.il
    My problem - it seems really complicated. Is anyone familiar enough with that exmple to suggest an alternative to deGetVector for setting pathVector?
    Thanks!!
  • swdesigner
    Here's the final solution (help from CCS). It does not avoid form interaction unfortunately - but uses hiRegTimer to ensure that the skill interacts with the form after sufficient delay :
    in .cdsinit :
    load("/path/to/CCSDescend.il")
    hiSetBindKey("Schematics" "<Key>e"  "CCSQueryUserSchHiDescend()")
    hiSetBindKey("Schematics" "Ctrl<Key>x" "CCSNoQueryUserSchHiDescend()")
    CCSDescend.il :
     procedure(CCSNoQueryUserSchHiDescend()
        envSetVal("schematic" "descendTarget" 'string "use viewNameList")
        if( (1 < car( geGetSelSet()~>numInst) )
            then
                hiRegTimer("hiFormDone(schDescendIterForm)" 2)
            else
        schHiDescendRead()
    procedure(CCSQueryUserSchHiDescend()
    envSetVal("schematic" "descendTarget" 'string "query user")
    schHiDescendRead()
