  3. Descending into a cell - skill function
  • Replies 18
  • Views 12549
swdesigner
swdesigner over 15 years ago
I currently bind my key to call schHiDescend, and work on the form.
Is there a way to bypass the form and call a function with the name of an instance in the current cellview to descend into it?
    Do the descend edit with nothing selected, and then hit F3. On the resulting form, pick "query view name list". From then onwards, all descends will pick the view in the config, or in the view list in the schematic editor options form - without raising a form.
    There's a cdsenv:
    envSetVal("schematic" "descendTarget" 'string "use viewNameList")
    To set this by default.
  • swdesigner
    Hi, My initial post was confusing. I want to avoid interacting with the form... so, is there a skill function I can use that takes the name of an instance and descends into that instance in the current cellview?
    Currently, the way I'm doing it is getting skill to interact with the form.
    My ultimate goal is to "save" my position when I Return To Top and hit another bindkey to return to the depth I was previously.
    Debugging top-level simulations, I traverse hierarchies a lot. Returning To Top is a bindkey - because that's easy - on the menu. Going the other way is hard - and I'd like to be able to do it..
    Right now, the only thing I can think of is more form interaction - each time I descend (which I always do using my bindkey, BTW), I will save the name of the instance, maybe using geGetSelSet or something, on a stack, and when I Return to Top, I have my "URL". When I want to "Return to Bottom", I'll have to process each instance.
    It can be done, I just want the path of least resistance:) If I can avoid form interaction, I'd like to do it.
    Thanks!
  • dmay
    dmay over 15 years ago
    Get your current location in the hierarchy with:
    geGetInstHierPath(hiGetCurrentWindow())
    Then try geSwitch or gePush to come back down.
    Derek
    geSwitch(
    w_windowId
    t_accessMode
    d_instId
    x_iteration
    x_row
    x_col
    [ g_cancel ]
    => t / nil
    Switches into an instance.
    gePush(
    w_windowId
    t_accessMode
    d_instId
    x_iteration
    x_row
    x_col
    [ g_cancel ]
    => t / nil
    Pushes into an instance.
  • skillUser
    skillUser over 15 years ago
    I think that you might be able to use the dePush() function for performing a descend edit/read with no form or other user interaction required. For the schematic environment, each of the descend functions are schHiDescend.* (the "Hi" secondary prefix indicates that the function has a Human Interface, perhaps a form, and so would not meet your needs). There is a deReturn() function, and also geReturn() and geReturnToLevel() functions.
    Hopefully this will help you in your task.
    Best regards,
    Lawrence.
  • swdesigner
    Perfect. Thank you both. I'm sure this will work. Thanks!
  • swdesigner
    One more thing I'm planning.. (in case you might already have the answer) I don't know how to make text (notes) on a symbol unselectable when instantiated. The resulting annoyance is that, when viewing a schematic with many instances, when intending to select an instance, one clicks on the text on the symbol and selects that instead. What I'd like to do is rig my descend-read bindkey to still descend into the instance correctly - because the user's intention is clear. There should be a way to derive the instance name from the selected text. Any clues will be greatly appreciated. Thanks!
  • swdesigner
    I tried dePush, I must be doing something wrong. I have a schematic open, there's an instance called "xtmux". Following the example for dePush, I did (in the CIW) myFileSpec = list( 'instanceName "xtmux" 'viewNameList "schematic symbol") returns (instanceName "xtmux" viewNameList "schematic symbol") Then I did dePush( myFileSpec window(11) "read" ) but this just pops up the Open File form.
    This needs to be a disembodied property list:
    myFileSpec = list(nil 'instanceName "xtmux" 'viewNameList "schematic symbol")
    You missed out the leading nil.
    With that, it should work.
  • dmay
    There is a selection filter in schematics for making the labels on a symbol unselectable. This is under the Options->Select Filter menu item at the bottom of the form. These settings can be saved in your .cdsenv.
    To make all instance objects unselectable, try this:
    envSetVal("schematic" "schematicSelectFilter" 'string "allSchObj")
    If you want instance pins selectable, try this:
    envSetVal("schematic" "schematicSelectFilter" 'string "allSchObj instancePins")
    This can be put in your .cdsenv like this:
    schematic       schematicSelectFilter   string  "allSchObj"
    Derek
  • swdesigner
    Thanks, that's the easier route.. I'll just use that.
     Thanks!
