  3. File browsing skill function in IC6.
  • Views 16368
tyanata
tyanata over 15 years ago
 Can anyonegive example for file browsing fuction in IC6 environment.
I know about ddsFileBrowseCB() function, but it does not work properly in IC6.
I know also about hiDisplayFileDialog(), but could not find some exapmle of its usage.
I want to have file browsing with filter *xls .
Best regards,
tyanata
  • skillUser
    skillUser over 15 years ago
    Hi Tyanata,
    Is the documentation not helpful to you?  I scanned it quickly and it seemed to make sense to me, here's something I tried briefly:
    procedure(myFileLookyCB(dialogPtr action)
    ;; possibly use the hiFileDialogSelection function here
    ?dialogName 'myFileLooky
    ?workingDir "/home/lawd/pc/Excel"
    ?filter "Spreadsheets (*.xls *.sxc *.csv)"
    ?callback "myFileLookyCB")
    Hope this helps!
    Lawrence.
    Also, what's wrong with the ddsFIleBrowseCB() function? I just tried it, and it works fine for me...
  • tyanata
    Thanks for the help!
    I thought that there is error in a function ddsFileBrowseCB(), because its usage was one of the root causes of IC5- IC6 diffence of the my script from the topic: http://www.cadence.com/community/forums/T/19220.aspx
     But after  more accurate search of the error root cause. It appeared that the error is different.
    Best regards,
    tyanata
  • tyanata
     Now I think, I already know what is different in IC5 -IC6 ddsFileBrowseCB command behaviour. In IC5 it behave as blocking mode, in IC6 as non blocking dialog box.
    OK, but you shouldn't really ever depend on forms being blocking - they should work based on the callback and whether it is blocking or not should then not impact you. Note, I didn't check if what you say is true (it could be - the implementation is very different in IC61 since it uses the QT file browser rather than a home grown one).
