  3. Bind the Mouse "right click button" to rotate function.
  • Views 2773
vinayab
vinayab over 15 years ago
 Hi All,
How to bind the Mouse "right click button" to rotate function.
Vinay
  • dmay
    dmay over 15 years ago
    The default bindkeys from Cadence should usually work if you are using Cadence commands. The following are Cadence's defaults:
    hiSetBindKey("Schematics" "None<Btn3Down> EF"        "schCmdOption()")
    hiSetBindKey("Symbol" "None<Btn3Down>EF"             "schCmdOption()")
    hiSetBindKey("Layout" "None<Btn3Down> EF"   "cmdOption()")
    If you have your own commands and want to add rotation, then you'll need to write your own "cmdOption" routine. You can do something like this:
    procedure(myCmdOption(@optional (modifier "None"))
        ;; modifier defines the modifier key from the bindkey (ie shift, ctrl, alt, meta)
        case(modifier
            ("None"
                ;; set different commands for different functions here.
                ;; default is Cadences cmdOption
                case(hiGetCurrentCmd(hiGetCurrentWindow())
                        ("My Command"
                            leRotateCB()
                        (t
                            cmdOption()
                        ) ;t
                    ) ;case
            ) ;None
            ("Shift"
                ;; default is Cadences cmdShiftOption
                        ("My Command"
                            doSomethingSpecial()
                        (t
                            cmdShiftOption()
                        ) ;t
                ) ;case
            ) ;shift
    hiSetBindKey("Layout"     "None<Btn3Down> EF"      "myCmdOption(\"None\")")
    hiSetBindKey("Layout"     "Shift<Btn3Down> EF"     "myCmdOption(\"Shift\")")
    Derek
