  3. error while using the function dbCreateParamInstByMaste...
  • Subscribers 150
  • Views 16054
error while using the function dbCreateParamInstByMaster
shashikumar22
shashikumar22 over 15 years ago
I am using this function in creating a program for auto creating a via on the point of click, however i the paramater passed are not actually implemented in the layout. i am using it this way via=dbCreateParamInstByMasterName(cv "REFLIB24" "V1" "layout" nil ctr "R0" 1 list(list("X" "float" x) list("Y" "float" y))) here i will pass the value of x and y , which will be the width and length of the via, the form is updated but the it is not implemented in layout i have also tries to use the combination of cdfUpdateInstParam(via) but it is taking some junk value, please suggest any improvement if you now
    Without knowing what parameters your via supports, answering this is rather hard. Maybe you can do:
    viaMaster=dbOpenCellViewByType("REFLIB24" "V1" "layout")
    foreach(mapcar param viaMaster~>parameters~>value list(param~>name param~>valueType))
    And post here the output?
  • shashikumar22
    hi Andrew,
    Thanks for your reply, actually i was out for vacation so could not reply on time. here is the output
     (("yNumber" "int")
         ("xNumber" "int")
         ("ByNumber" "boolean")
         ("PlaceCenter" "boolean")
         ("Y" "float")
         ("X" "float")
        ("V1_purpose" "string")
        ("y_layer" "string")
      ("x_layer" "string")
         ("Type" "string")
    That suggests it ought to work. There must be something wrong - because this is basic functionality - so either the pcell is not really responsive to that parameter value - or something wierd is going on.
    I suggest you log a service request with Cadence Customer Support.
  • shashikumar22
    hi Andrew,
    Can you please check the code ?? Actually it is a very basic script and i have made it to start in skill, Please suggest me any modification if you can ???
    procedure(decision(b)
     if(b != nil then
     cv = geGetEditCellView()
     a=list(b b)
     let((m1 m0 m2 m1b m0b m2b nwbx cnt ctr x y via)
     m1 = dbGetTrueOverlaps(cv  a list("M1" "drawing") 32)
     m0 = dbGetTrueOverlaps(cv  a list("M0" "drawing") 32)
     m2 = dbGetTrueOverlaps(cv  a list("M2" "drawing") 32)
     m1b=car(m1~>bBox)
     m0b=car(m0~>bBox)
     m2b=car(m2~>bBox)
    if(m0 && m1 && m2 then
     choiceGUI()
      else
      if( m0 && m1 && !m2  then
       nwbx=bbox(m0b m1b); to get bbox of the overlap area
     cnt=centreAndWL(nwbx)
     ctr=car(cnt)
     x=nth(1 cnt)
     y=nth(2 cnt)
     via=dbCreateParamInstByMasterName(cv "REFLIB" "V1"  "layout" nil ctr "R0" 1 list(list("X" "float" x) list("Y" "float" y)))
      else if(!m0 && m1 && m2 then
       nwbx=bbox(m1b m2b); to get bbox of the overlap area
     ctr=car(cnt)
     dbCreateParamInstByMasterName(cv "REFLIB" "V2" "layout" nil ctr "R90" 1)
      else
      println("no overlap found")))
      );if
      ); first if
    )); procedure to make desicion
    procedure(bbox(mo m1)
     let((mox1 moy1 mox2 moy2 m1x1 m1y1 m1x2 m1y2 lx ly rx ry)
      mox1=xCoord(lowerLeft(mo))
      moy1=yCoord(lowerLeft(mo))
      mox2=xCoord(upperRight(mo))
      moy2=yCoord(upperRight(mo))
      m1x1=xCoord(lowerLeft(m1))
      m1y1=yCoord(lowerLeft(m1))
      m1x2=xCoord(upperRight(m1))
      m1y2=yCoord(upperRight(m1))
     if(mox1>=m1x1
      then lx=mox1
     else lx=m1x1);if for lowerleft x value
     if(moy1>=m1y1
     then ly=moy1
     else ly=m1y1);if for lowerleft y value
     if(mox2<=m1x2
     then rx=mox2
     else rx=m1x2);if for upperright x value
     if(moy2<=m1y2
     then ry=moy2
     else ry=m1y2);if for upperright y value
     newbbox=list(list(lx ly) list(rx ry))
     );let
    );procedure for getting bbox of overlap
    procedure(getlocation()
    let((pts)
    pts=enterPoint(
     ?prompts list("Enter a point.")
           );enterpoint
            if(pts != nil  then
            decision(pts) ;
            getlocation())
               ); procedure to get click point
    procedure(centreAndWL(ox)
    let((w w1 w2 l1 l2 l cy cx cy1 cx1 c out)
    l1=xCoord(upperRight(ox))
    l2=xCoord(lowerLeft(ox))
    w1=yCoord(upperRight(ox))
    w2=yCoord(lowerLeft(ox))
    l=l1-l2
    w=w1-w2
    if(minusp(l)
    then l=(-1)*w
    else w=w); if w is negative
    if(minusp(l)
    then l=(-1)*l
    else l=l); if l is negative
    cy1=w/2
    cy=w1-cy1
    cx1=l/2
    cx=l1-cx1
    c=list(cx cy)
    out=list(c w l)
    );procedure
    procedure(choiceGUI()
    let((VIA)
      rf = hiCreateRadioField(
                        ?name        'Vselect
          ?prompt      "Select the Via Needed"
          ?choices     list("VIA1" "VIA2" "Both")
          ?defValue    "Both"
     myform = hiCreateAppForm(?name 'myform
                     ?formTitle "Shashi"
        ?fields list(
        list(rf       0:20 220:20 200)
      hiDisplayForm(myform)
      choiceVia=myform->Vselect->value
      );let
      );procedure for display of choice
    There's not much I can advise without seeing the actual REFLIB to know how the via is defined.
    The only thing I would point out is that your code could do with some indentation, and also having sensible names for the functions with prefixes to ensure they are unique and don't clash with somebody else who also writes a function bbox or getlocation...
    The reason I suggested logging a service request is that then you might be able to share the technology data so that one of our support team can take a look armed with sufficient data to be able to diagnose the problem.
