  3. How to copy some objects from current level to current cellview...
  • Subscribers 152
  • Views 15648
How to copy some objects from current level to current cellview which is in edit-in-plcae ?
Charley Chen
Charley Chen over 15 years ago
Hi All,
I want to copy some objects that can cross hierarchy from top level (or one of it upper level) into
current cellview which is in edit-in-plcae ? (From Top to bottom)
I can get objs = geGetSelSet() in current cellview (maybe top level or one of its upper level),
I edit-in-place in one cellview , How to copy objs into current cellview ?
My problem is how to get the correct transform  (From Top to bottom)
foreach(x objs
          dbCopyFig(x  hiGetCurrentWindow()->cellView  transform)
Thank you,
Charley
  • Austin CAD Guy
    Austin CAD Guy over 15 years ago
     Here is some code that may help. It has been tested only one level down so you have to create multiple levels and test again.
     procedure( dbCopyDown( objs )
      let((
              fp
           transform)
        fp = geFindPathToCellViewInst( geGetTopLevelCellView() geGetEditCellView() )
        transform = reverseTransform( dbGetInstTransform( fp ) )
        foreach( obj objs
           dbCopyFig( obj geGetEditCellView() transform )
        ) ; ** foreach obj **
      ) ; ** let **
    ) ; ** procedure dbCopyDown **
    procedure( reverseTransform( transform )
      let((
              point
           rot)
        point = car( transform )
        rot = cadr( transform )
        case( rot
           ( "R0"
             list( list( -xCoord( point ) -yCoord( point ) ) "R0" 1 )
           ( "R90"
             list( list( -yCoord( point ) xCoord( point ) ) "R270" 1 )
           ( "R180"
             list( list( xCoord( point ) yCoord( point ) ) "R180" 1 )
           ( "R270"
             list( list( yCoord( point ) -xCoord( point ) ) "R90" 1 )
           ( "MX"
             list( list( -xCoord( point ) yCoord( point ) ) "MX" 1 )
           ( "MY"
              list( list( xCoord( point ) -yCoord( point ) ) "MY" 1 )
           ( "MXR90"
             list( list( -yCoord( point ) -xCoord( point ) ) "MXR90" 1 )
           ( "MYR90"
             list( list( yCoord( point ) xCoord( point ) ) "MYR90" 1 )
        ) ; ** case rot **
      ) ; ** let **
    ) ; ** procedure reverseTransform **
  • Charley Chen
    Hi Austin ,
    Thank you for help it. It's helpful.
    I will  try  multi levels .
     Charley
