  3. Need help regarding verilog stream in
  • Views 15107
Paramjeet
Paramjeet over 15 years ago
I am using verilog stream in option with the  cadence-ic-/5141-usr5 version.
I have a top level module with 400 instances and all connected in series with a resistance of a specified value.
The schematic generated by the utility is not in form to understand, with long routes of connectivity and so on.
Is there any skill utility that can generate schematic if i give the list of instances in order and the resistance value for all signals between them. I have the cadence library that contains the symbols for the modules used in verilog.
Or is there any skill utility which I can run on the generated schematics through the verilog stream in option to make the connection more straight forward.
Pleas suggest
  • Quek
    Quek over 15 years ago
     Hi Paramjeet
    I am still a little unclear on your issue. May I know if this is a correct description of your problem?
    You can successfully imported a verilog netlist using verilogIn from IC5141USR5 but you find that the instances in the schematic are not placed in good positions and hence makes the schematic hard to understand. You are wondering if there are any scripts or another tool that can do the same job as verilogIn but produce a better schematic.
    If the above is correct, there are no other tools besides verilogIn. A skillscript might be able to do the job but I think it would take quite some time to code such a script.
    Best regards
    Quek
  • Paramjeet
    Hi Queek,
    Thanks for the response. You understood the problem statement very well. This is what I am looking for.
    Since currently there is no such skill script, so I have to work with existing schematics, or have to code myself.
    In case you come across any such thing, please let me know.
    Thanks once again
    Regards
    Paramjeet Singh
