  3. How to Retrieve the value of dX and dY in the current w...
  • Replies 18
  • Views 27971
How to Retrieve the value of dX and dY in the current window
ClintMeyer
ClintMeyer over 15 years ago
I would like to create a script that will automatically move whatever I have selected in a layout window by the same amount as the last move.  The last move/copy/stretch relative distance is displayed in the layout window as dX and dY (standing for delta X and delta Y i presume).  Is there a skill function that returns that value?  I looked under the hiGetCurrentWindow() and it was not there.
 Thanks for any help
 Clint
  • cessej
    cessej over 15 years ago
    Its the same problem as discussed in the previous replies. Deltax/&y is wrong when the snap cursor is not "Any Angle".
    My code actually get's the object's bounding box changes when performing move or copy. By doing this, you don't care about the snap cursor because your calculating the delta between old position(old bbox) to new position(bbox)
    Though its working, I still preferred to short one. I hope we can get the updates.
    And it seems to assume pre-selection, and I don't think it handles stretch. I didn't try to work out why (no time, sorry - already spent longer than I meant to on trying to find the elegant solution, and I'm sure it's not insurmountable). Anyway, will focus on trying to get a short, elegant solution!
  • cessej
    Yes, the problem is my code is not suitable for stretch.
  • ClintMeyer
    Pre-selection is an oft used case due to how repeat commands works and whether or not I want to maintain my selected set after the command finishes.
    Also stretch would need to work.
    While I only use diagonal and any angle snapping modes, I rarely move along the diagonal (it only gives me flexibility inside of a split command), so I can modify dmay's code and apply the orthogonal case to diagonal. I will try that out to see if it works.
    Clint
  • ClintMeyer
    Guys
     Thanks for the help, this is a very useful function that will see a lot of use across my entire layout team.  Your effort and expertise is greatly appreciated.
    I have brought all the pieces together and fixed a couple issues.  I also have a couple questions  (See end)
    Functional Bug
    needed absolute value when evaluating which term of delta variable was larger
    Code Bug
    added =list( to the abGetDxDy.lastDelta variable in orthogonal and diagonal mode
    ;Procedure to set a variable that represents the relative X and Y for the last move, copy or stretch
     procedure(abGetDxDy(@optional (win hiGetCurrentWindow()))
     let((refPoint curPoint)
      refPoint=leGetRefPoint(geGetEditCellView(win))
      curPoint=hiGetCommandPoint(win)
      when(refPoint && curPoint && member(hiGetCurrentCmd(win) '("Move" "Copy" "Stretch"))
       case(hiGetCurrentWindow()~>snapMode
             ("anyAngle"
             abGetDxDy.lastDelta=mapcar('difference curPoint refPoint)
             ("orthogonal"
               delta = mapcar('difference curPoint refPoint)
               if(abs(car(delta)) >= abs(cadr(delta))
               abGetDxDy.lastDelta=list(car(delta) 0.0 )
               abGetDxDy.lastDelta=list(0.0 cadr(delta))
             ("diagonal"
    ;bindkey to make it work
    hiSetBindKey("Layout" "<Btn1down>EF" "abGetDxDy() mouseAddPt()")
     Now my questions.
    I have the variable working as I want inside of stretch/move commands.  However in my quest to get it working inside of copy I am having an issue.  With the bindkey below I need to press it TWICE to make it work ONCE and I get a warning in the icfb.  I think this comes back to my lack of understanding of enter function.  The reason I am trying to do it this way is because I want to maintain the selected set after the copy.
    Can you give me a hint on how to make this bindkey work?
    hiSetBindKey("Layout" "Meta<Key>=" "leHiCopy() le0CopyForm->segSnapMode->value = \"anyAngle\" le0CopyForm->DeltaXField->value = car(abGetDxDy.lastDelta) le0CopyForm->DeltaYField->value = cadr(abGetDxDy.lastDelta) _leApplyDeltaCB (hiGetCurrentWindow()) " )
    *WARNING* hiGetWindowStackPts: enter function is inactive
    Clint
    Clint,
    As I mentioned in the separate email discussion, having discussed with R&D, there is no function to truly get the "snapped" X and Y (and hence dX and dY) values. The snapping is actually done by the application - and may vary depending on the command currently being performed - so it's actually not that straightforward to emulate in all cases. However, I think the way you've done it is a reasonable compromise. I have filed an enhancement request to get hold of the XY value from the banner - because the "hi" interface knows what the current snapped value is in order to display in the banner and also to update the cursor location - but that will be for a future release.
    In terms of implementing your additional bindkey, I would not try to do it by interfacing with the leHiCopy() function and piggybacking on the form. For a start, the form identifier will vary depending on how many technologies you have open. Secondly it's blocking, so you'd have to start messing with hiRegTimer() to ensure your updates got applied. Thirdly you're tied to private information about the field names on the form, and these may (and indeed have) changed over time. For example, I don't think the callback was called that in the version I tried.
    So a better approach is probably to implement a function like this:
    procedure(abMoveOrCopyByDelta(function delta @optional selectNew)
        let((new (win hiGetCurrentWindow()) cvId (transform (list delta "R0" 1)))
            when(delta && listp(delta) && numberp(xCoord(delta)) &&
                numberp(yCoord(delta)) && !cddr(delta)
                cvId=geGetEditCellView(win)
                new=foreach(mapcar fig geGetSelSet(win)
                    funcall(function fig cvId transform)
                when(selectNew
                    geDeselectAll(win)
                    foreach(fig new
                        geSelectFig(fig)
                new
    hiSetBindKey("Layout" "Meta<Key>=" "abMoveOrCopyByDelta('dbCopyFig abGetDxDy.lastDelta)")
    The function copes with both copy and move. You can call:
    abMoveOrCopyByDelta('dbMoveFig abGetDxDy.lastDelta)
    and also if you want the copy to select the newly copied figures, you would do:
    abMoveOrCopyByDelta('dbCopyFig abGetDxDy.lastDelta t)
    Note that in the implementation of abGetDxDy above it is using ~>snapMode - I think it should be ~>segSnapMode as that's what is updated by the copy command (that's the "edit" snap mode rather than the "create" snap mode).
  • PeteVT
    PeteVT over 8 years ago in reply to Andrew Beckett
    Hello, I was interested in implementing what was discussed in this thread and would like to know if there were any new developments in how this could be implemented. We use ICADV12.1 and 12.3 depending on the project. Is it possible there is a simpler implementation for the delta value calculation for example?
    Thanks very much,
    Pete
    Andrew Beckett over 8 years ago in reply to PeteVT
    I don’t think anything has changed related to this.
