  3. How to Retrieve the value of dX and dY in the current w...
  • Replies 18
  • Views 27970
How to Retrieve the value of dX and dY in the current window
ClintMeyer
ClintMeyer over 15 years ago
I would like to create a script that will automatically move whatever I have selected in a layout window by the same amount as the last move.  The last move/copy/stretch relative distance is displayed in the layout window as dX and dY (standing for delta X and delta Y i presume).  Is there a skill function that returns that value?  I looked under the hiGetCurrentWindow() and it was not there.
 Thanks for any help
 Clint
    Clint,
    This shows how to do it:
     procedure(abGetDxDy(@optional (win hiGetCurrentWindow()))
     let((refPoint curPoint delta)
      refPoint=leGetRefPoint(geGetEditCellView(win))
      curPoint=hiGetCommandPoint(win)
      when(refPoint && curPoint
        delta=mapcar('difference curPoint refPoint)
      printf("dx=%L dy=%L\n" xCoord(delta) yCoord(delta))
    ; change the bindkey to what you want
    hiSetBindKey("Layout" "<Key>d" "abGetDxDy()")
  • ClintMeyer
    DELETED DOUBLE POST
  • ClintMeyer
    Hey Andrew
     Thanks for the procedure.  Unfortunately, I was not fully understanding how Dx and Dy work.  Let me give you some background on what I am looking for.
     Back in 1998 when I worked for IBM, they had in house CAD tools.  The layout editor (GYM) had as a standard feature the ability to store the Dx/Dy for the previous data manipulation event (whether move/copy/stretch/etc..).  Then a command could be issued that would move the current selected set of objects by the previous Dx Dy in the positive or negative direction.  This was a surprisingly handy data manipulation command that was used more often that it would seem.
     Your abGetDxDy.il gets the data but to use that skill code, I would have to do the following.
     1) select data and initiate the move command (order is only important if you want to keep the set of items selected after you finish the move command and whether you want "repeat commands" to work)
    2) click with the left mouse button where you want to reference your move from (depends on whether the user uses inFix or not, but lets save that debate for another day LOL)
    3) move your mouse to the new location for the move
    4) inititate the abGetDxDy() procedure and store the results in a variable
    5) left click with the mouse to set the new location for the selected set
    Now I can recall the variable with DxDy stored to use as input into a relative move command.  That is the simple part.
    What I would really like is a way to grab the relative location of the cursor (your abGetDxDy) at the same moment as when I click to set the new location (step 5).  My pea sized brain imagines that one would need to build new procedure that wraps around leHiMove/Stretch/Copy/etc.... and uses those new procedures instead of leHiMove/Stretch/Copy/etc....
     If you can show me one, i can figure out the others.  I would be really interested to see how you do it (copying is the best way for me to learn).
    I have a feeling that this has something to do with enter function, which I still dont have a complete understanding of.
     Anyway, thanks again for your help!!
     Clint
    Hi Clint,
    This appears to do the trick:
     let((refPoint curPoint)
      when(refPoint && curPoint && member(hiGetCurrentCmd(win) '("Move" "Copy"))
        abGetDxDy.lastDelta=mapcar('difference curPoint refPoint)
    hiSetBindKey("Layout" "<Btn1down>EF" "abGetDxDy() mouseAddPt(t)")
    It redefines the left mouse button (in enter function mode) to record the last delta when in Move or Copy commands. You can then access the last delta outside by using abGetDxDy.lastDelta
    You would need to extend the list of commands in the member() statement to include those that you want to cover.
    Let me know how you get on!
  • ClintMeyer
     Brilliant!!!  I really like how concise the code is.  I can start to understand it.  It is so close to what I need I can smell it.  I found 2 things
    1) I had to remove the (t) from MouseAddPt() in the bindkey as no argument is needed.
    2) This one is a bit trickier.  Around 1/2 of the time when a layout designer is manipulating data, the SnapMode will be Orthogonal so the mouse cursor accuracy is only sensitive to 1 axis rather than 2.  This saves the layout designer time because when he is certain that the final location is orthogonal to the reference click, the VLE "cursor" (either a box or a dotted line cross shape) will be orthogonal to the reference point .  This "VLE cursor" will almost always be different than the mouse cursor when moving/copying/stretching with SnapMode set to Orthogonal. The hiGetCommandPoint() returns the position of the mouse cursor not the VLE cursor.  I looked through Finder and tried as many cursor type commands as I could find to see if one would display the VLE cursor position upon click, but they all seemed to use the mouse cursor.  I tried hiGetDbuPoint and others.
    Thanks again for the help.
     Clint
  • ClintMeyer
    DELETED DOUBLE POST
    Some of my posts were getting caught in a filter.
    Hi Clint,
    I'll check in the morning - should be able to refine it to do what you want (admittedly I did very little testing as I'm rather short of time at the moment).
  • dmay
    dmay over 15 years ago
    One way would be to replace:
    with a conditional that checks the snap value and then sets the delta accordingly. For anyAngle, the current code works. For orthogonal, use the larger of the dx and dy and set the other to 0. For diagonal, it is a little trickier. It looks like the delta is only in the x dir when the dx is more than twice dy. The dx and dy would be the same when dx > 0 and dy > 0 and dx is not more than twice dy or less than half dy. You can experiment with this in your window.
    case(hiGetCurrentWindow()~>snapMode
      ("anyAngle"
      ("orthogonal"
        delta = mapcar('difference curPoint refPoint)
        if(car(delta) >= cadr(delta)
          abGetDxDy.lastDelta(car(delta) 0.0)
          abGetDxDy.lastDelta(0.0 cadr(delta))
      ("diagonal"
        println("more work is needed here")
      (t
        println(strcat(hiGetCurrentWindow()~>snapMode " not supported"))
    Or, maybe Andrew has a simpler solution. ;-)
    Derek
  • cessej
    cessej over 15 years ago
    I changed the code because it doesn't work correctly from the beginning.
      ;gets object's bbox after enterpoint
      abGetDxDy.refPoint=append(abGetDxDy.refPoint list(car(getBbox(geGetSelectedSet()))))
      ;recording the last form
      if(hiGetCurrentCmd(win) then abGetDxDy.lastForm=hiGetCurrentCmd(win))
      ;gets delta if from Move or Copy form
      ;only gets if enterfunc are all finish
      if(member(abGetDxDy.lastForm '("Move" "Copy"))  && !hiGetCurrentCmd(win) then
        ;for dbCopyShape or dbCopyMove
        abGetDxDy.lastDelta=mapcar('difference car(last(abGetDxDy.refPoint)) car(abGetDxDy.refPoint))
        ;for geCopySelSet
        abGetDxDy.firstPoint=car(abGetDxDy.refPoint)
        abGetDxDy.lastPoint=car(last(abGetDxDy.refPoint))
        ;reset
        abGetDxDy.refPoint=nil
        abGetDxDy.lastForm=nil
    hiSetBindKey("Layout" "<Btn1down>EF" "mouseAddPt(t) abGetDxDy()")
    procedure(getBbox(@optional objects "l")
      let( (lx rx ly uy)
       unless(objects && forall(obj objects dbobjectp(obj))
          objects = geGetSelectedSet()
        ); unless
        when(objects
          lx = xCoord(lowerLeft(car(objects)~>bBox))
          rx = xCoord(upperRight(car(objects)~>bBox))
          ly = yCoord(lowerLeft(car(objects)~>bBox))
          uy = yCoord(upperRight(car(objects)~>bBox))
          foreach(obj objects
            lx = min(lx xCoord(lowerLeft(obj~>bBox)))
            ly = min(ly yCoord(lowerLeft(obj~>bBox)))
            uy = max(uy yCoord(upperRight(obj~>bBox)))
            rx = max(rx xCoord(upperRight(obj~>bBox)))
          ); foreach
          list(list(lx ly) list(rx uy))
        ); when
      ); let
    ); procedure getBbox
    Not sure why cessej rewrote it (it's not clear to me what the original problem he/she was trying to resolve).
    Anyway, I've dug around a bit and haven't yet found a way of getting the "snapped" point. Looking at geAdjustPoint, the documentation suggests that this ought to work, but I believe that despite the documentation, it seems to always assume "Any Angle" as the snap mode. In practice it would probably need to know whether the create or edit snap mode was in place, but that's not it.
    Ideally there would be an API to get the snapped cursor location; I can't find one though. Otherwise Derek's approach is probably the only alternative.
    I'll ask R&D.
    Note the argument to mouseAddPt() is in the IC615 bindkeys; it's not there before. I don't think it's absolutely essential though - effectively it allows the application to do mfg snapping or something like that.
