  3. Floating number precesion in OCEAN/CIW
  • Views 2703
greatqs
greatqs over 15 years ago
I found a floating number in OCEAN or CIW can has only 6 digits precision after decimal point.
For example, in OCEAN shell, I type 1.123456789 but I get 1.123457 actually. So I get some calculation error when dealing this kind of floating point.
Could anyone advice me how to avoid this issue? Thanks a lot!
    Actually the numbers in OCEAN (and SKILL, since OCEAN is SKILL) are stored in double precision floating point - which means they have about 15.5 decimal significant figures. What you're seeing is that the default print representation in SKILL is 7 significant digits. For example:
    defMathConstants('myMath)
    myMath.PI => 3.141593
    printf("%g\n" myMath.PI) => 3.14159
    printf("%.15g\n" myMath.PI) => 3.14159265358979
    sstatus(fullPrecision t)
    myMath.PI => 3.141592653589793
    So the sstatus fullPrecision flag can be set so that by default floating point numbers are displayed with full precision rather  than being output with "%.7g" format.
    You will not get rounding errors at the 7 digit level because of this normal truncation, since it's only at output. For example, if I do:
    myMath.PI-3.141592 =>  6.535898e-07
    so you can see the next digits being revealed. You will of course get rounding errors down at the end of the 52 bit mantissa though (i.e. around 15.5 digits).
    So it's not an issue to do with rounding, merely how the numbers are displayed.
