  3. repeat copy in IC51
  • Views 18453
repeat copy in IC51
zhisong
zhisong over 15 years ago
Greeting, everyone.
In IC5.1 if I want to copy shape to multi, I have to count the repeat number to specify row/column. It's boring.
I want to copy shape to one, and then press a bindkey(such as "dot"), which can repeat the copy action.
Do you think SKILL can realize it?
  when(hiGetCurrentCmd(wid)
the copy source, I can use geGetSelSet() to collect.
But I wonder, how I can get the target position, I have less experience to control mouse in SKILL.
Please show me some comment, Thanks
-Jason
  • Quek
    Quek over 15 years ago
    Hi Jason
    I think we can have a simple implementation of the function using the following skillscript. : )
    Load it in ciw and execute it using:
    CCSrepeatCopy(1.0 0)
    To repeat the copy, press "." in layout window.
    To clear the bindkey for ".", press "ctrl ."
    Perhaps you can try adding a small form so that it is easier to enter the values.
    Best regards
    Quek
    procedure( CCSrepeatCopy(xDist yDist)
       let( (x y selSet offsetX offsetY xDist1 yDist1)
          selSet=geGetSelSet()
          foreach(obj selSet
             offsetX=0
             offsetY=0
             when(xDist>0 offsetX=rightEdge(obj~>bBox)-leftEdge(obj~>bBox))
             when(yDist>0 offsetY=topEdge(obj~>bBox)-bottomEdge(obj~>bBox))
             x=xDist+offsetX
             y=yDist+offsetY
             geSelectFig(dbCopyFig(obj nil list(x:y "R0")))
             geDeselectFig(obj)
          ) ;foreach
          sprintf(xDist1 "%L" xDist)
          sprintf(yDist1 "%L" yDist)
          hiSetBindKey("Layout" "." strcat("CCSrepeatCopy(" xDist1 " " yDist1 ")"))
       ) ;let
    ) ;procedure
    hiSetBindKey("Layout" "ctrl<Key>." "hiSetBindKey(\"Layout\" \".\" \"\")")
    repeatcopy.il
  • zhisong
    Hi Quek,
     Yes, this code can work well if I give it the xDist and yDist.
    But it's also difficult for me to catch xDist/yDist from the first Copy.
    I have tried to use leGetRefPoint(), but it's real time, after the new shapes generated, refPoint become the new value.
    Do you have idea to catch the offset from first copy?
    -Jason
     Jason in that case you might want to look at the code in this thread.
  • zhisong
    Hi AB & Quek,
     Now combine with your comment, I have built the code for repeat copy.
    Thanks for all of your support.
    -Jason
