  3. Using defmacro badly...
  • Views 15283
markbeck
markbeck over 15 years ago
Greetings all,
I'm trying to do something which I suspect may not be possible, but I figured I should ask.
I wish to create a macro that allows the user to write the contents of the @rest into a file.
e.g.
MyFileMacro( This is what I want to be written to a file)
I found that if I defined the following macro, I can get close:
(defmacro MyFileMacro (@rest body)
    sprintf(t_body "%L" `,body)
    `FunToWriteOutFile(,t_body)
This sorta works, but I have to clean up what is sent to `,body before writing it out to a file. `,body appears to be a bunch of function strings and so I end up with lots of '(' and ')' characters.
The issue I'm encountering is when the user enters in characters that are interpreted as a badly formed macro call...
e.g. MyFileMacro( blah{blah} )
This gives me a syntax error since skill is trying to interpret the contents of body before sending it to `,body.
 Basic question:
Is there a way to force the @rest body contents to be identically returned without any interpretation, such that I can then shove it into a string, or just get it to always interpret it as a string?
Mark
    Mark,
    Fundamentally this is not doable. The arguments to the macro are still parsed by the SKILL parser, just not evaluated. This means it will follow SKILL syntax - so if you were to use SKILL operators it would try to convert into appropriate function calls. So
    sstatus(printinfix nil)
    MyFileMacro(hello + world)
    Would end up with "(plus hello world)"
    (I think - didn't test it).
    If you ended up with part of a SKILL expression, it will just break:
    MyFileMacro(hello +)
    So no, you can't do this. Macros are not intended for this kind of thing.
    Isn't it easier just to put the quotes in yourself?
    Regard,
  • markbeck
     Ya, I suspected that this was the case.
    From a programmer's standpoint, it's easier to deal with strings, however from a user's standpoint, if they have to write out something to a text file that needs quote characters they have to escape them..
    e.g.
    If I wanted to write out:  The "cat" in the "hat"
    I would have to enter the string as:  "The \\"cat\\" in the \\"hat\\""
    It makes it a bit harder to read the contents...
    Mark
