  3. Store recall layout editor view positions
  • Views 16656
blankman
blankman over 15 years ago
Hi all,
I am hoping to store and recall viewing positions in layout editor. I am taking the window bounding box from the layout view with geGetWindowBox(), which gives 2 coordinates. This stores the xy position and zoom level of the layout editor automatically. I am hoping to use these coordinates again to set the layout view position but can't locate a suitable command to do so. Is it possible? Something along the lines of geSetWindowBox() would sort it but doesn't seem to exist.
Brian.
    Brian,
    hiZoomIn is what you want. The second argument to hiZoomIn is the box you want to zoom to.
    However, isn't this the same as View->Save/Restore that's in the tools already (for as long as I can remember)? In IC5141 it was under Window->Utilities->Save/Restore View.
  • blankman
    Ah, cheers Andrew, I didn't see hiZoomIn. That sorted it out. Handy to know the Utilities route too. I'll have to take a closer look at the menu options.
    Rgds,
    Brian.
  • blankman
    Andrew, another quick question, below is the code I am using. However, when I execute the second procedure without having executed the first the variable wid1 is undefined and I get an error message "unbound variable wid1". Is there anyway around this, say to check if a variable is yet defined and if not to exit the function or execute another function?
    Brian.
     procedure(BSstoreView1()
        wid1=geGetWindowBox(hiGetCurrentWindow())
        sprintf(message "View 1 stored\n")
        when(message
                            win=geGetEditCellViewWindow(geGetEditCellView())
                            point=hiGetPoint(win)
                            geDeleteAllHilightSet(geGetWindowCellView())
                            ;Set label size depending on window zoom
                                    x2 = xCoord(cadr(geGetWindowBox(hiGetCurrentWindow())))
                                    x1 = xCoord(car(geGetWindowBox(hiGetCurrentWindow())))
                                    dx = x2 - x1
                                    labelheight = dx/100
                            when(point
                                    hs=geCreateHilightSet(geGetWindowCellView()
                                            abDynamicDisplay.lpp || '("y4" "drawing"))
                                    geAddHilightLabel(
                                            hs
                                            point
                                            message
                                            abDynamicDisplay.justify || "centerCenter"
                                            abDynamicDisplay.orient || "R0"
                                            abDynamicDisplay.font || "roman"
                                            abDynamicDisplay.height || labelheight
                                            nil
                                    hs->enable=t
                                    geRefresh()
                                    hiRegTimer("geDeleteAllHilightSet(geGetWindowCellView()) geRefresh()" 25)
            message = nil
    );procedure
    hiSetBindKey("Layout" "Ctrl Shift<key>KP_Home" "BSstoreView1()")
    procedure(BSreselectView1()
        hiZoomIn(win wid1)
        sprintf(message "View 1 selected\n")
        when(message
                                    dx = x2 - x1
                            when(point
                                    geAddHilightLabel(
                                            hs
                                            point
                                            message
                                            nil
                                    hs->enable=t
                                    geRefresh()
        message = nil
    );procedure
    hiSetBindKey("Layout" "Ctrl<key>KP_Home" "BSreselectView1()")
    Hi Brian,
    Yes, use:
    when(boundp('wid1)
    By the way, I'd really recommend you give any global variables a sensible prefix so that they don't clash with other things.  We generally recommend customers using a prefix which begins with uppercase - so BrianWid1 would a better name ;-)
  • blankman
     Perfect, thanks andrew. I had tried the boundp command alright, only I was missing the ' for the list. Sorted now. I'll make sure and use more suitable prefixes too, or local variables where possible, I have noticed sometimes programs affecting the operation of Cadence, this may well have been the reason :)
    Brian
