  3. Pycell causing crash in 64Bits
  • Subscribers 150
  • Views 15701
kb how
kb how over 15 years ago
While i'm evaluating pycell in Cadence IC614 and IC615, noticed that it is working fine in 32bits. But when i switch to 64 bits, the pycell is not longer available, even though we managed to instantiated it into the cellview, but its failed to view. Same issue as when i trying to stream-out cellview which has pycell in it, the virtuoso crash.
Is there any alternative ways to solve this issue, since this is a critical issue.
  • skillUser
    skillUser over 15 years ago
    Hi How,
    I may get flamed for this but there is an article you may wish to consider (even though it may not help you in your hour of need): The Case For SKILL PCells
    You would need to go to the PyCell vendor (CiraNova I guess) for support, unless someone on this forum can help you.
    Lawrence.
  • kb how
    Hi Lawrence,
    Ya, me too. Anyway, thanks a lot for your sharing.
    I should also point out that non-SKILL pcells are not supported by Cadence. This means that no testing is done; we cannot accept testcases containing them; and anyway it would be problematic debugging problems related to them as we do not have access to the source code for the non-SKILL pcell evaluator.
  • kb how
    Thanks Adrew,
    I found a similar article related to this.
    /blogs/ii/archive/2010/01/13/q-amp-a-a-cadence-view-of-interoperable-pcells.aspx
