  3. cadence callback error -unbound variable
  • Views 2501
whlinfei
whlinfei over 15 years ago
Hi, I am using Cadence 5.1.0 , IBM PDK , 65nm process. There is a "synthesize" function in the properties of on chip inductor where the callback should generate a table of inductors that are within the range of user defined parameters. However, when I clicked the button, no table was generated. Instead, I can see the following error message in the log window. schCDFCallback('isdb_start") searching for tables for target L = "5n" CDF: an error occured when evaluating callback. callbcak: isdb_start->callback =>tl10lpeISDBCB('synthsize) Message: error eval : unbound variable -tl10lpe_symindp_wireopt14 Thanks in advance. Linfei
    Contacting IBM would make sense, since it's their PDK. However, you may be lucky as other users may have hit the same problem, or maybe one of the IBM guys who subscribe to the forum can answer.
