  3. modify corner of rod object
  • Views 18541
Dexter073
Dexter073 over 15 years ago
How can I use the leModifyCorner to a rectangle (or polygon) created by a ROD object? If only a databse object can be modifed by leModifyCorner; is it possible to first create a polygon object, modify the corner, and somehow convert it to a ROD object? I need ROD objects for aligning.
I tried this sample code:
pcDefinePCell(
list( ddGetObj( "my_library") "my_cell_view" "layout")
( w 1.44)
( l 2.14)
(polyoffx 0.94)
(polyoffy 0.2)
(poly_length 1)
(poly_width 1)
(polyLayer "POLY")
(activeLayer "ACTIVE")
);end of default values
 ;Define contents of the pcell
let((poly active)
poly= rodCreatePolygon(
?layer list(polyLayer "drawing")
?pts list( 0:0 poly_length:0 poly_length:poly_width 0:poly_width )
leModifyCorner( poly list(t t t t) t 0.1 4)  ; compains poly is not a  database object
active = rodCreateRect(
?layer list(activeLayer "drawing")
?pts list( 0:0 l:0 l:w 0:w )
leModifyCorner( active list(t t t t) t 0.1 4)  ; compains active is not a  database object
rodAlign(
?alignObj active
?alignHandle "lowerLeft"
?refObj poly
?refHandle "lowerLeft"
?xSep polyoffx
?ySep polyoffy
Many thanks in advance. Kindly provide a small code (or modify the existing) to make it work; I am still a newbie..
    You'd have to use active~>dbId to get the database id that leModifyCorner needs as its first argument.
    HOWEVER you must not use leModifyCorner in a pcell. It's not a legal function to use in a pcell; only core SKILL, and functions with db, dd, tech, cdf, rod and a few pc functions are legal in pcells. This is because they must be available in standalone programs that access the database (for example, the stream interface, Cadence physical verification tools, and ITK DB applications); these applications will not have the layout editor functions built in. So you'd find that it works in Virtuoso, but as soon as you try to access the database outside of a tool with the layout editor built in, you'll get a pcell-eval failure. This can be worked around in IC61 using express pcells (which allows Virtuoso to build a snapshot of each variant to avoid needing reevaluation in external tools, but you would need to be careful to ensure that this is setup consistently for all users).
    You'd have to write your own function to chamfer the corners (not actually that difficult, particularly for a rectangle.
  • Dexter073
    Thank you so much Andrew; it works with the suggestion you have given. However, as you suggested, I will try to write a function to chamfer corners to avoid problems. Thanks!
  • Michael2b
    Michael2b over 13 years ago
    Do you have have a SKILL function to chamfer the corners of a rectangle in a pcell?
  • skillUser
    skillUser over 13 years ago
     Hi Michael,
    To my knowledge there is not a single SKILL function to do this which would work within a PCell.  I am looking into this, at least for the rounded corner case.  Do you need a straight-line chamfer?  If so you can create some triangles over the corners on another (temporary) layer and then use something like dbLayerAndNot with these shapes and the original rectangle to create a new shape with those corners chamfered/removed.
    If I write any code for this I will post it.
    Lawrence.
  • Michael2b
    Thanks Lawrence,
    I do not need a stright-line chamfer. I am using IC5.1.41 and I need to create a bond pad pcell with rounded corners.
    Michael
