  3. Print model card parameter names
  • Views 16771
ChrisEAS
ChrisEAS over 15 years ago
Hi ..
Is there a way to display all parameter names of a model card using SKILL? I wanted to create a Spectre sensitivity analysis statement using those parameters. I've been searching for a while already... I'd much appreciate your help! Thanks.
Chris
    Chris,
    openResults("/path/to/psf") ; if not open already
    selectResult('model)
    outputs() ; gives a list of all the model names in the results - for example "nch"
    report(?name "nch") ; will print out the parameters for that model.
    Read the docs if you want to do things like write to a file.
  • ChrisEAS
    Great, thanks! However, this will output the report as a string which needs to be parsed. I was hoping to avoid the trouble and access the model card as an object or list. I suppose there's no such thing?
     Regards, Chris
    Chris,
    It was the "Print" in the title of the post that made me think you wanted to print it ;-)
    Anyway, this is easily doable. You can do:
    dataTypes() ; outputs ("mos3" "bsim4") - whatever model types you have
    outputs(?type "mos3") ; outputs just the models which match that type
    outputParams("bsim4") ; available parameters for that model type
    pv("nch" "vto") ; outputs a specific parameter
    getData("nch")->vto ; does the same thing
    getData("nch")->? ; lists all the available parameters (like outputParams, but for a given model name)
    getData("nch")->?? ; lists alternating parameter-value pairs
  • ChrisEAS
     Splendid, thanks! (Sorry for the confusion with the title..)
