  3. SKILL script to bind "CreatePath" with "CreateBus"?
  • Views 2079
CrisIba
CrisIba over 15 years ago
Hi all! I am interested in finding/writting a script that would help me create a bus with multipart paths. If I have a big bunch of wires coming out of a decoder and I want to route them all along together, is there a possibility to make the metal transistions automatically and have also automatically added VIAs (just like in CreatePath)? Thanks, Cristina
  • skillUser
    skillUser over 15 years ago
    Hi Cristina,
    Please take a look at a previous thread on this topic for a starting for a solution. Hopefully this will get you started.
    Best regards,
    Lawrence.
  • CrisIba
     Hi and thanks! Already been digging on that one! I found a way of formulating this one more simple, so I'll keep asking for a little help.
     Can we add a "change to layer" feature (like in "create path" ) to the regular "create a bus" script?
     Thanks again!
     I should point out that in IC615 you can create buses as a standard function in both the "L" and "XL" tiers of the layout tool (XL being connectivity driven), including the ability to change layer. So don't reinvent the wheel if you're on IC61X - it's already there.
  • CrisIba
     Hey Andrew and thanks!
    Unfortunately I am working with internal technologies that won't have a compatible PDK for IC61X soon, so I kinda have to reinvent the wheel.
    In IC5141 you could use the bus creation capabilities in the turbo toolbox (covered in the documentation) - again these allow you to change layer. The use model is a little different, but it still would avoid reinventing the wheel.
