  3. What is the most efficient approach to record each line...
  • Replies 16
  • Views 22852
What is the most efficient approach to record each line from a input file ?
Charley Chen
Charley Chen over 15 years ago
 Hi All,
I use table to record each line & its value , but it will become slower and slower when time left .
Though I can get table[A11100] = list(1000000 2000000 3000000 4000000) very quickly , But must when it finished loop.
What is the best way to do it ?
;write a template file
        getCurrentTime()
        outPort = outfile("test")
        count = 1000000
        fileCount = 1
        for(i 1 count
            fprintf(outPort "1000000 2000000 3000000 4000000\n")
        close(outPort)
        getCurrentTime()
        ;read each line to record
        nextLine = nil
        inPort = infile("test")
       getCurrentTime()
 when(inPort
      fileCount = 1
      table = makeTable("table" nil)
      while(gets(nextLine inPort)
              qq = parseString(nextLine "\n")
              str = sprintf(nil "A%d" fileCount)
              table[str] = list(1000000 2000000 3000000 4000000)
              fileCount++
      );while
 );when
      inPort = nil
      getCurrentTime()
Thank you,
Charley
    Charley,
    No, that won't help. The issue in your case was the allocation of the strings used as keys, and the list cells used as values. Splitting the table into multiple pieces wouldn't help that - it's the same amount of keys and the same amount of values. It would just make it harder to code, and add no value (in fact it would probably take more memory, in fact).
    So it's not the table that is the issue here - it's the keys and values that are the problem.
  • Charley Chen
    Andrew,
    In fact , the content of table maybe like and the line count of the file is maybe thousand or 10 thousand or million or  10 million or ...
     table[A:1] = list(1000000 2000000 3000000 4000000)
    table[A:112] = list(1000000 2000000 3000000 4000000 500 30 11 22) ; maybe or longer , The length of the list is not fixed .
    If the keys and values that are the problem , Do you have better suggestion or another coding?
    I need to store each line quickly and access it .
    Thank you for help.
    Charley
    Charley,
    If you make the key an integer rather than a string, that will be more efficient. Other than that, it's very hard to make a suggestion without knowing what you're really doing. Fundamentally data needs memory - there's no avoiding that!
  • Charley Chen
    Andrew,
    If I use integer as key as below, I can not know the group A or C or ... , no index name
    table[0] = list(1000000 2000000 3000000 4000000)    ==> table[A0] = list(1000000 2000000 3000000 4000000)
    table[11110] = list(1000000 2000000 3000000 4000000 10 22)  ==>  table[C11110] = list(1000000 2000000 3000000 4000000 10 22)
    whta I want is to quick store and quick look up the value from the table[
    Thank you,
    Charley
    Charley,
    I cannot help you as I simply do not have enough information to go on. Every time your requirements seem to change - I have no idea what these "groups" that you are talking about mean - the examples have only been abstract with no information about what you are trying to achieve. Generic questions can only get generic answers, and vague questions can only get vague (or no) answers.
    Here's my generic answer (which I've stated several times): Quick storage and quick lookup are easy with tables - however, you have to be aware that if you have an enormous  number of keys or values, you may need to use needNCells to improve the performance in the allocation of the storage for those keys and values.
  • Charley Chen
    Andrew,
    Thank you for help .
    Charley
