  3. What is the most efficient approach to record each line...
  • Replies 16
  • Views 22842
What is the most efficient approach to record each line from a input file ?
Charley Chen
Charley Chen over 15 years ago
 Hi All,
I use table to record each line & its value , but it will become slower and slower when time left .
Though I can get table[A11100] = list(1000000 2000000 3000000 4000000) very quickly , But must when it finished loop.
What is the best way to do it ?
;write a template file
        getCurrentTime()
        outPort = outfile("test")
        count = 1000000
        fileCount = 1
        for(i 1 count
            fprintf(outPort "1000000 2000000 3000000 4000000\n")
        close(outPort)
        getCurrentTime()
        ;read each line to record
        nextLine = nil
        inPort = infile("test")
       getCurrentTime()
 when(inPort
      fileCount = 1
      table = makeTable("table" nil)
      while(gets(nextLine inPort)
              qq = parseString(nextLine "\n")
              str = sprintf(nil "A%d" fileCount)
              table[str] = list(1000000 2000000 3000000 4000000)
              fileCount++
      );while
 );when
      inPort = nil
      getCurrentTime()
Thank you,
Charley
    Charley,
    As I've mentioned several times - the SKILL profiler would help. In general it would be best to profile your real code (I presume this is a toy example), but when I profiled the read above, the time was mostly spent in gc (garbage collection). This I ran with a local file, and it spent 377 seconds out of 383 (in IC5141) in gc. Note that gc does not mean necessarily that there's garbage, but when it needs to allocate a chunk more memory for various objects it will first try to scan and collect garbage before allocating new space.
    Because you're creating a lot of string and list cells (1 million and 4 million respectively), I can tell SKILL to pre-allocate memory for these. If I add:
    needNCells('list 4000000)
    needNCells('string 1000000)
    before reading the file, the reading loop takes 5.6 seconds (including population of the table).
    Note that in IC615 (not sure quite when in IC61 it happened) work was done on the chunk sizes so that it spends less time in gc - it was reduced to 105 seconds. But with the preallocation, it drops down to nothing in gc.
    You can also see the effect of this if you read the file twice - that's because the table will get recreated and all the previous keys and content will become garbage and reclaimed - once - but it then already has plenty allocated.
    gcsummary() is useful to find out what is allocated.
  • Charley Chen
    Andrew,
    We don't have the license, so I can't use it. // Tools - SKILL Development
    How to set it correct number ?
    In this case ,  table[str]  must dependent the line count of a file , e.g.  wc -l  qq => 1000000 ,
    if wc -l qq => 10000000 (10 million )  , needNCells('string 10000000)  , Is that right ?
    If table[str] = list(1000000 2000000 3000000 4000000 500 600) , needNCells('list 60000000) // 60 million , Is that right ?
    What does 10 million means ?  I just give it a large number , it crashed.
    Thank you,
    Charley
    Charley,
    You don't necessarily need to get it to be the number of lines - it will just minimize the amount of work it has to do.
    Allocating 10 million (or 60 million) of anything is a fairly unusual thing to do. Given that only you know what you're doing here - only you can know how you might be able to determine how many entries you need.
    The number is the number of slots needed. In the case of the strings, you had one string per line in the file (the key into the table). So for a million lines, that's a million strings. For the lists, the number is the number of list cells - and so there's one per list cell per row - hence 4million. gcsummary() tells you how big each type is, and how much total memory has been allocated for each type. As more are needed though, it will automatically allocate more memory - assuming you don't run out.
    If you start to allocate very large numbers, maybe you're running out of memory - it has to store the data somewhere. Particularly if you're running in 32 bit mode, there's a limit of roughly 2^32 bytes (less than 4Gbytes in practice) of available memory - even if your machine has much more. I don't know which version you're using, but in IC5141 only "layout" can be run in 64 bit mode (which would give you access to more memory). From IC614 the "virtuoso" executable can be run in 64 bit mode.
  • Charley Chen
    Andrew,
    I need to collect each line & its data for look up acording each line information , using table is the best ?
    I know the prblem is in    table[str] = list(1000000 2000000 3000000 4000000)  ,
    as long as i comment it out , It become very fast . But nothing to get .
    Thank you,
    Charley
    Charley,
    Yes, a table would be the best solution almost certainly, as it's a hash table and offers near random-access lookup times (compared with lists which are sequential).
    However, you've got to store the data somewhere - and the needNCells() is just a way of giving SKILL a hint how much data you're likely to be creating, to avoid it having to incrementally check for garbage and then allocate chunks as it goes along. These are the kind of trade-offs that you have to make and balance carefully when you are optimizing for large data.
  • Charley Chen
    Andrew,
    Once I use needNCell('list 1000000) or needNCell('string 1000000..)  , Will it always available ?
     I will change and repeat using needNCell while working,
    Should I purge it when the program is done ? I am afraid I allocate too memory ....
    Thank you,
    Charley
    Charley,
    Calling needNCell() multiple times is not a problem - it does not add that number, but sets the upper limit. This means you cannot reduce it once allocated, because  you've pre-allocated a pool ready to be used by SKILL. However, SKILL will be able to reuse any of the list or string cells which are no longer in use (for list cells or strings respectively) - this is what garbage collection is all about. For example, before I run your example reading 1 million lines into a table, if I run gcsummary() :
    Type       Size   Allocated     Free      Static   GC count
    list         12     1593344    26124     1191936          3
    string        8      167936    81680      229376          0
    After running it, I see:
    list         12    50089984   719256     1191936          6
    string        8     8966144   818144      229376          3
    So if once you're done you do:
    table=nil
    gc() ; force a garbage collection rather than waiting until the system thinks one is necessary
    gcsummary()
    list         12    50089984 48842892     1191936          7
    string        8     8966144  8859424      229376          3
    So what you're seeing there is now it has freed up lots of list and string slots - which can be reused by other programs within the same session.
    Hope that helps!
  • Charley Chen
    Andrew,
    ;Calling needNCell() multiple times is not a problem ...
    (1)
    Can I use QQ() to define?
    procedure( QQ()
    needNCell('list 10000..)
    needNCell('string 10000..)
    );pro
    (2) Use two or three table to store the same value is better than use one table to store ?
    Thank you,
    Charley
     Charley,
    The answer to question 1 is yes, it's fine to call it inside a procedure (in fact that was what I was doing when I was checking your code).
    I don't understand the second question. You'll need to give some more details for me to be able to answer.
  • Charley Chen
    Andrew,
    I table = makeTable("table" nil) to store 1 million record ,  If not use needNCell  , it will become slower later ...
    Can I use table1to1000 = makeTable("table1to1000" nil)  ; table1001to2000 = makeTable("table1001to2000" nil) ....
    Is that helpful ?
    Thank you,
    Charley
