  3. How to find points of a hole inside a polygon?
  • Views 17648
JaneCA
JaneCA over 15 years ago
The case is, in a polygon, there are unknown numbers of holes, could be of different sizes, locations unknown.  I need to find and group the points that belong to each hole.  All the points from the polygon including enclosed holes are available.  Anybody has ideas?  Thanks.
    Sounds as if the function dbLayerHoles() is what you want.
  • JaneCA
    Thank you Andrew.  But is this function only available for IC6?
    No. I can't check to be absolutely certain as I'm off line, but from a quick search it's been there since IC5033 USR2. So about 8 years...
  • JaneCA
    Thank you very much.  Let me give it a try.
  • JaneCA
    Andrew,
    I am looking at the Example from the manual.  I am not really sure how to use this function.  My case is that, I have a m1 polygon, and there are some holes inside of it.  How do I apply this function so that the holes are returned as new objects?  Thank you.
    Jane
  • JaneCA
    Thank you Andrew.  I figured it out and it is working now.  Thanks so much.
