  3. How to set value of Inductor via skill in IC614?
  • Views 14568
Sumlose
Sumlose over 15 years ago
I want to do some simulations with the value of Inductor from 100pH to 200pH can i write an ocean to change the value of inductor or res? to do a loop or something.. thx for help~
  • skillUser
    skillUser over 15 years ago
    Hi, Set the inductance to a design variable, say "myind" and then is available for sweeps, e.g. a parametric sweep, or a "manual" sweep using Ocean. In Ocean the desVar() command allows you to inspect and set the value of a design variable. Hopefully this gets you started? Regards, Lawrence.
