  3. How to close "Undeine Packet" Dialog Box when open a cellview...
  • Views 3677
How to close "Undeine Packet" Dialog Box when open a cellview ?
Charley Chen
Charley Chen over 15 years ago
Hi All,
It will tell you Merge or ....., I will choose merge .
Thank you.
Charley
    Charley,
    Your question is not clear - surely you just hit the "Yes" or "No" button on the dialog box?
    If you don't want the dialog to appear, you can do:
    envSetVal("graphic" "packetDialogBoxes" 'boolean nil)
  • Charley Chen
    Ardrew,
    Sorry for not clear question.
    If I want to hit "Yes" button  when first open cellview , How to do it ?
    Thank you,
    Charley
    Charley,
    You move your mouse over the "Yes" button and click the left mouse button!
    If you don't want the popup to appear - use the envSetVal() function I described earlier.
  • Charley Chen
    Andrew,
    I want it to appear , and hope it chooses "Yes" button when the dialog box appears then disappear.
    Thank you,
    Charley
    Your only hope would be to use something like this:
    hiRegTimer("hiDBoxCancel(packetDialogBox)" 20) geOpen(?lib "opamp090" ?cell "objectExample" ?view "layout")
    The 20 allows it to stay up for 2 seconds (up to - but it depends - it may not stay as long as that if it takes a long time to open the cellView).
    The best solution is to stop it opening in the first place.
  • Charley Chen
    Andrew,
    Thank you very much.
    Charley
