  3. putting 2 strings together in axlSetJobPolicy
  • Views 15091
ejm20
ejm20 over 15 years ago
I am trying to create a script that will work with ADEXL's job policies and the script needs to build
the command line.
 Whats the correct syntax to put the 2 two togther?
This will get the command field
axlGetAttachedJobPolicy()->jobsubmitcommand
and lets say it has the following:
-J newJob
This line will replace the jobsubmitcommand:
axlSetJobPolicyProperty( "ADEXL_mmsim_m" "jobsubmitcommand" "nc run -D -C mmsim_m_2  " )
I need it to look like this:
axlSetJobPolicyProperty( "ADEXL_mmsim_m" "jobsubmitcommand" "nc run -D -C mmsim_m_2  -J newJob " )
so how can I put the 2 togther?   strcat or something?   It looks like   axlSetJobPolicyProperty()  will not evaluate
any variable .
  • skillUser
    skillUser over 15 years ago
    Yes, you should be able to use strcat(), something like this example (not tested):
      strcat("nc run -D -C mmsim_m_2 " axlGetAttachedJobPolicy()->jobsubmitcommand)
    I hope that this works and is what you are looking for.
    Lawrence.
  • ejm20
    Thanks Lawrence!!...its seem to be working
     Rick
  • ejm20
    I spoke too soon, this is what it generates
     nc run -D -C mmsim_h_1 nc run -D -C mmsim_h_1 nc run -D -C mmsim_h_1 nc run -D -C mmsim_h_1 nc run -D -C mmsim_h_1 nc run -D -C mmsim_h_1 -J Hclass -r+ RAM/1000
     probably because it does this for each test that ADEXL creates.   Here the bulk of the code:
     ;;;  tb_pnr_pg_switches
    ;;;  load "/projects/svl/882XV/882XV_A/rmattern/cds_libs/skill/ADEXL_tokenSet.il"
    ;; defining the PreRun function
    (define (PreRun session_name sdb_highandle mode_string test_name)
            (printf "Launching a new run %L %L %L %L\n" session_name sdb_highandle mode_string test_name)
           ;; pre run customization
            tests=axlGetTests(sdb_highandle)
        jobPolicyName=axlGetAttachedJobPolicy()->name
        distmethod=axlGetAttachedJobPolicy()->distributionmethod
            println( jobPolicyName )
             ;; traversing all the tests and changing the mt option as per the requirement
       foreach(  test_name cadr(tests)
          if(  axlGetEnabled(axlGetTest(sdb_highandle test_name)) then
              printf("test %s is enabled\n" test_name)
              testSession=axlGetToolSession(session_name test_name)
              mt_opt=testSession~>simID~>data~>env~>data~>turboOpts~>data~>mtOption~>value
              if(eq(strcmp(mt_opt "Manual")  0) printf("  Manual MT will be disabled!!! \n"))
              if(eq(strcmp(mt_opt "Disable")    0) printf("Disabled MT \n"))
              if(eq(strcmp(mt_opt "Auto")     0) printf(" Auto MT will be disabled!!! \n"))
              if(eq(strcmp(distmethod "Local") 0) then printf(" Turning off the MT options for this test \n")
                testSession~>simID~>data~>env~>data~>turboOpts~>data~>mtOption~>value="Disable" )
              tool_opt=testSession~>simID~>data~>env~>data~>turboOpts~>data~>uniMode~>value
          println( tool_opt )
          extraCmdOpts=axlGetAttachedJobPolicy()->jobsubmitcommand
              println( extraCmdOpts )
    ;; Spectre
              if(eq(strcmp(tool_opt "Spectre") 0) then printf(" Spectre run - 1 token \n")
             axlSetJobPolicyProperty( "ADEXL_mmsim_h" "jobsubmitcommand"  strcat("nc run -D -C mmsim_h_1 " axlGetAttachedJobPolicy()->jobsubmitcommand) )
             axlSetJobPolicyProperty( "ADEXL_mmsim_m" "jobsubmitcommand"  strcat("nc run -D -C mmsim_m_1 " axlGetAttachedJobPolicy()->jobsubmitcommand) )
             axlSetJobPolicyProperty( "ADEXL_mmsim_l" "jobsubmitcommand"  strcat("nc run -D -C mmsim_l_1 " axlGetAttachedJobPolicy()->jobsubmitcommand) )
             ) ;if
