  3. symbol PCELL extraction issue.
  • Replies 18
  • Views 24611
fishbulb15
fishbulb15 over 15 years ago
I have created a symbol, schematic and layout pcell. Everything seemed to be working correctly until I wanted to start LVS-ing the the pcell. I first ran into an issue where it required that my schematic be extracted since last edit. So I followed the instructions here: ___Schematic PCell: Schematic cellviews modified since last extracted___ support.cadence.com/.../ ------->Which seemed to solve that issue. But now I am getting "ERROR: Netlister: symbol of instance modified, please re-extract cell ''." Is there something like : dbCreateProp(pcCellView "schGeometryLastRecorded" "time" getCurrentTime() ) dbCreateProp(pcCellView "lastSchematicExtraction" "time" getCurrentTime() ) to add to the symbol pcell?? How can I get this to work.. Thank you, Mitchell Cohen
    Mitchell,
    Bit hard to read the above, but my guess is that you want to just add a call:
    dbSetConnCurrent(pcCellView)
    in your code (rather than the above). That will then work in both IC5141 and IC61X (which use different mechanisms for this) - you didn't say which version  you're using.
  • fishbulb15
    Andrew, After writing it I noticed that all my formatting left for some reason... I am using IC5141. So, trying your suggestion of the new command did not help unfortunately. Let me try to describe the problem in a bit more detail. I have created three PCells one for a symbol view,a schematic view and a layout view. I have an instance of this PCell (instance call "data") instantiated in a containing schematic,lets call it "ROM". When I go to netlist the ROM schematic to the ROM layout using Calibre LVS (not for simulation) it errors out with the error: "Netlister: symbol of instance 'data' modified, please re-extract cell 'ROM'. Previous to this problem (which could be solved with your solution above and with the solution that I used before) I saw that the schematic of the PCell was not being seen as extracted, now that is not the problem any more. Your suggestion led me to probe a bit further and I determined that all three instance views returns true for dbIsConnCurrent(). Could there be something else I am missing? If you need more information, please let me know! Thank you!
    For the formatting - maybe you're using Chrome - there's a known issue with formatting with the forums when using Chrome.
    Assuming that checking-and-saving the ROM schematic doesn't fix it, it may be a matter of ensuring that the last change dates do not change from previous builds. It's a bit surprising though...
    I suggest you log a service request so that this can be investigated more.
  • fishbulb15
    Andrew, You are right...I am using Chrome. Could you elaborate on what you mean by this: "it may be a matter of ensuring that the last change dates do not change from previous builds". Thanks. Mitchell Cohen
    In IC5141 it's a matter of setting cv~>instancesLastChanged to be an old date - so it appears that the symbol hasn't changed. That said, I've not normally had to do this with a pcell - so I'm a bit surprised...
    You'd do:
    dbDisableCellViewCounter(pcCellView)
    dbReplaceProp(cv "instancesLastChanged" 'time "Jun 27 18:00:00 1999")
    or similar.
    In IC615, you'd just put dbDisableCellViewCounter(pcCellView) at the beginning of the pcell code.
  • fishbulb15
    Andrew,
     After looking at the cells a bit more I noticed that the modifiedButNotSaved parameter was equal to "t".  How can I set this to "nil" using SKILL to see if that will solve my problems.
     Thank you,
    Mitchell Cohen
    Mitchel,
    If you're talking about the pcell submaster having modifiedButNotSaved equal to t that's perfectly reasonable - it should do that. You can't change that (it can't be saved because it's a variant, and it is inevitably modified because of the fact that the pcell code builds the symbol or schematic or whatever).
  • fishbulb15
    Andrew,
     Thank you for sticking with me on this...
    I have determined that the problem is with the OSSHNL (hierarchical netlister) not for a spectre netlist but for an auCdl netlist .  If you have any "far-out" reasons as to why it says:
    "ERROR: Netlister: symbol of instance 'data' modified, please re-extract 'ROM'.
    ERROR(OSSHNL): Error(s) found during netlisting. The netlist may be corrupt or may not be produced at all."
    Thank you,
    Mitchell Cohen
    Hi Mitchell,
    I'll do some experiments on this tomorrow. I'm sure I've netlisted similar cases before - but I'll re-test - and maybe post an example for you to try and compare.
    BTW to everyone watching - we're trying to fix the multiple email notifiers on the forums (all being well, this email will only appear once!)
    Hi Mitchell,
    Try this code - it works for me in IC5141 - I can place an instance and CDL it out with no issues. You'll probably need to change the lib name near the top of the code, which is where it places the new "busset" pcell.
    /* busset.il
    Author     A.D.Beckett
    Group      Custom IC, Cadence Design Systems Ltd.
    Machine    SUN
    Date       Jul 11, 2004
    Modified
    By
    SKILL code for creating the "busset" pcell schematic, symbol,
    and the CDF as well.
    SCCS Info: @(#) busset.il 04/20/11.13:51:09 1.2
    let( (library cell pcellId)
        library="training"
        cell="busset"
        unless(ddGetObj(library)
            error("Couldn't open library %L" library)
        ; First the schematic
        pcellId=pcDefinePCell(
            list(ddGetObj(library) cell "schematic" "schematic")
            ; Formal parameters
                (buswidth 6)
                (busvalue 0)
            ; Code itself
            let(( cv master instId netH netL
                busOut driveName driveNet)
            cv = pcCellView
            ; Convert parameters, and figure out drive net name
            when(buswidth<1 buswidth=1)
            for(bit 0 buswidth-1
                if(driveName then
                    driveName=strcat("," driveName)
                else
                    driveName=""
                ) ; if
                driveName=strcat(
                    if(busvalue<bit>==1 "hi" "lo")
                    driveName
            ) ; for
            ; open master cell view
            master = dbOpenCellViewByType( "basic" "cds_thru" "symbol" nil "r" )
            ; create the nets
            netH=dbMakeNet(cv "hi")
            netL=dbMakeNet(cv "lo")
            busOut=dbMakeNet(cv sprintf(nil "bus<%d:0>" buswidth-1))
            driveNet=dbMakeNet(cv driveName)
            ; create the terminals
            dbCreateTerm(netH netH~>name "inputOutput")
            dbCreateTerm(netL netL~>name "inputOutput")
            dbCreateTerm(busOut busOut~>name "inputOutput")
            ; create the instance of cds_thru
            instId =
                dbCreateInst(
                    cv master sprintf(nil "thru<%d:0>" buswidth-1)
                    0:0 "R0"
            ; Connect it up
            dbCreateConnByName(busOut instId "dst");
            dbCreateConnByName(driveNet instId "src");
            ; Make the connectivity look up to date - not always needed, but
            ; Assura needs this, for example.
            dbSetConnCurrent(cv)
            dbClose( master )
            t
            ) ; let
        dbSave(pcellId)
        dbClose(pcellId)
        ; Now the symbol
            list(ddGetObj(library) cell "symbol" "schematicSymbol")
            ; Formal parameters
                (buswidth 6)
                (busvalue 0)
            ; Code itself
            let(( cv netH netL
                busOut figH figL figBus hp ps pl bw lh
                pxc label)
            cv = pcCellView
            ; Various dimensions
            ; half pin size
            hp=0.025
            ; pin spacing
            ps=0.125
            ; pin length
            pl=0.250
            ; box width
            bw=1.4375
            ; label height
            lh=0.0625
            ; param label x coord
            pxc=0.5
            ; create the shapes - first the pins
            figH = dbCreateRect(cv list("pin" "drawing") list(-hp:-hp hp:hp))
            dbCreateLine(cv list("device" "drawing") list(0:0 pl:0))
            figL = dbCreateRect(cv list("pin" "drawing") list(-hp:-ps-hp hp:-ps+hp))
            dbCreateLine(cv list("device" "drawing") list(0:-ps pl:-ps))
            figBus = dbCreateRect(cv list("pin" "drawing")
                list(2*pl+bw-hp:-hp 2*pl+bw+hp:hp)
            ) ; dbCreateRect
            dbCreateLine(cv list("device" "drawing") list(pl+bw:0 2*pl+bw:0))
            ; Then the boxes
            dbCreateRect(cv list("device" "drawing") list(pl:-2*ps pl+bw:ps))
            dbCreateRect(cv list("instance" "drawing") list(0:-2*ps 2*pl+bw:ps))
            ; create the nets
            ; create the pins
            dbCreatePin(netH figH)
            dbCreatePin(netL figL)
            dbCreatePin(busOut figBus)
            ; Put some labels for the pins
            dbCreateLabel(cv list("pin" "drawing") pl+ps/2:0
                netH~>name "centerLeft" "R0" "stick" lh)
            dbCreateLabel(cv list("pin" "drawing") pl+ps/2:-ps
                netL~>name "centerLeft" "R0" "stick" lh)
            dbCreateLabel(cv list("pin" "drawing") bw+pl-ps/2:0
                busOut~>name "centerRight" "R0" "stick" lh)
            ; And other symbol labels
            label=dbCreateLabel(cv list("annotate" "drawing7") bw+pl-ps/2:ps*1.5
                "cdsName()" "centerRight" "R0" "stick" lh)
            label~>labelType="ILLabel"
            label=dbCreateLabel(cv list("annotate" "drawing") pxc:0
                "cdsParam(1)" "centerLeft" "R0" "stick" lh)
            label=dbCreateLabel(cv list("annotate" "drawing") pxc:-ps
                "cdsParam(2)" "centerLeft" "R0" "stick" lh)
            t
            ) ; let
        dbSave(pcellId)
        dbClose(pcellId)
    ; Now create the CDF
        let( (cellId cdfId )
            unless( cellId = ddGetObj( library cell )
                error( "Could not get cell %s." cell )
            when( cdfId = cdfGetBaseCellCDF( cellId )
                cdfDeleteCDF( cdfId )
            cdfId  = cdfCreateBaseCellCDF( cellId )
            ;;; Parameters
            cdfCreateParam( cdfId
                ?name           "buswidth"
                ?prompt         "Bus Width"
                ?defValue       6
                ?type           "int"
                ?display        "t"
                ?name           "busvalue"
                ?prompt         "Bus Value"
                ?defValue       0
                ?type           "int"
                ?display        "t"
            ;;; Simulator Information
            cdfId->simInfo = list( nil )
            cdfId->simInfo->UltraSim = '( nil )
            cdfId->simInfo->ams = '( nil )
            cdfId->simInfo->auCdl = '( nil )
            cdfId->simInfo->auLvs = '( nil )
            cdfId->simInfo->cdsSpice = '( nil )
            cdfId->simInfo->hspiceD = '( nil )
            cdfId->simInfo->hspiceS = '( nil )
            cdfId->simInfo->spectre = '( nil )
            cdfId->simInfo->spectreS = '( nil )
            ;;; Properties
            cdfId->formInitProc            = ""
            cdfId->doneProc                = ""
            cdfId->buttonFieldWidth        = 340
            cdfId->fieldHeight             = 35
            cdfId->fieldWidth              = 350
            cdfId->promptWidth             = 175
            cdfId->paramLabelSet           = "buswidth busvalue"
            cdfId->paramDisplayMode        = "parameter"
            cdfId->paramEvaluate           = "t nil nil nil nil"
            cdfSaveCDF( cdfId )
        ) ; let
    ) ; let
