  3. Qt plotter funnies...
  • Views 14858
markbeck
markbeck over 15 years ago
Greetings all,
I'm using IC6.1.5.500.4
I'm seeing some behavior where the plotter isn't plotting what is assigned to a variable correctly.
For example, if I type the following into the CIW and execute it, I get two sine-waves
a = getData("/out") ; a single sine-wave period over 1nS
b = sample(a 0 1n "linear" 250p)
newWindow()
plot(a b); plots two sine-waves
If (for example) I then put the following in the CIW (single copy and paste):
a = getData("/out")
b = sample(a 0 1n "linear" 250p)  newWindow()
plot(a)
hiRegTimer("plot(b)" 30);
This produces the expected sinewave and triangle wave
However, if I then type : plot(a b); I get the incorrect two sinewaves plotted again!
If I type in:
  plot(a) ; hit enter
  plot(b) ; hit enter
This produces the correct plots again.
I tried this with awvPlotWaveform() and got the same results.
It's as though the Qt plotter can't handle two waveforms in the same plot command that have different x-axis number count. And you can't call the commands very quickly without confusing the plotter.
I found that if I switch back to the Java plotter, this doesn't appear to be an issue.
 Is this a known bug? Is there a work-around?
Mark
    Mark,
    It's a bug - quite a serious one in my opinion. Are you the same as "markbe" who has previously posted on these forums (from that I can glean who you work for, assuming that hasn't changed in the last couple of months)? Perhaps you can send me a direct message with your contact details, and then I'll file an SR and CCR on your behalf.
    Best Regards,
    Mark,
    CCR  920309 filed for this.
