  3. How to create dockable form in skill
  • Replies 7
  • Views 18811
RushMehta
RushMehta over 14 years ago
I am trying to create a dockable form so that it can be docked to existing schematic window.
I am able to create popup gui using hiCreateAppForm and hiDisplayForm. When hiDisplayForm is  executed skill code stays there till the form is closed using 'close' button.
However that's not true when I dock it.
I used hiCraeteDockWindow and hiDockWindow functions to successfully dock the form.  After executing hiDockWindow, skill code goes to next line and it will eventually exit the code. Which means the form is docked in schematic but its non-functional now as it can't reference any variables.
How do I keep the skill code alive after docking the form ? Or is there any other way to achieve the docked form ?
Thanks in advance,
Rushang
    Rushang,
    Please post your code - I expect you've made some mistake in the scoping of variables - but hard to know without seeing what you've done.
  • RushMehta
     I suspect the same but couldn't get it to work without using global variables. And I want to avoid using global variables as users may have more than one schematic open with such docked form.
    My code is too big with many procedures defined in it. But here is a scaled down version which shows the problem.
    In the code popupform() functions correctly but dockform() throws error in CIW when user click load file button. For dockform() to work you need to have a schematic (or any session) window open
    procedure( popupform()
        let( (fileLocation loadFileButton myForm)
            fileLocation = hiCreateFileSelectorField(
                    ?name           'fileLocation
                    ?mode           'existingFile
                    ?prompt         "Choose a file"
                    ?editable       t)
            loadFileButton = hiCreateButton(
                    ?name           'loadFileButton
                    ?buttonText     "Load File"
                    ?callback       "printf(\"Loading file from popup form %s\n\" fileLocation->value)")
            myForm = hiCreateAppForm(
                    ?name           'myForm
                    ?formTitle      "My Form which should be popup"
                    ?buttonLayout   'Close
                    ?fields         list( list(fileLocation 10:10 400:20 100)
                                            list(loadFileButton 415:10 80:30))
                    ?unmapAfterCB           t)
            hiDisplayForm(myForm)
        ); let
    procedure( dockform()
        let( (fileLocation loadFileButton swin myForm2 dockForm myDock)
                    ?name           'fileLocation
                    ?mode           'existingFile
                    ?editable       t)
                    ?callback       "printf(\"Loading file from docked form %s\n\" fileLocation->value)")
            swin = hiGetSessionWindow(hiGetCurrentWindow())
            myForm2 = hiCreateAppForm(
                    ?name           'myForm2
                    ?formTitle      "My Form which should be docked"
                    ?unmapAfterCB           t)
            dockForm = hiCreateDockWindow(
                    ?appType        "Docked Form"
                    ?widgetType     "form"
                    ?handle         'dockedForm
                    ?title          "Docked Form"
                    ?form           myForm2)
            myDock = hiDockWindow(
                    ?window         dockForm
                    ?session        swin
                    ?side           'right)
        ); let
    Thanks for looking into this.
     Rushang
    Rushang,
    Try this modification of your code:
        let( (fileLocation loadFileButton )
                    ?name           'fileLocation
                    ?mode           'existingFile
                    ?editable       t)
                    ?callback       "printf(\"Loading file from popup form %s\n\" myForm->fileLocation->value)")
                    ?name           'myForm
            ?dontBlock t    ; with this your previous code would have failed
                    ?unmapAfterCB           t)
        ); let
        let( (fileLocation loadFileButton swin dockForm myDock)
                    ?name           'fileLocation
                    ?mode           'existingFile
                    ?editable       t)
                    ?callback       "printf(\"Loading file from docked form %s\n\" myForm2->fileLocation->value)")
            ; or this
                    ;?callback       "printf(\"Loading file from docked form %s\n\" hiGetCurrentForm()->fileLocation->value)")
                    ?name           'myForm2
                    ?unmapAfterCB           t)
                    ?widgetType     "form"
                    ?handle         'dockedForm
                    ?form           myForm2)
                    ?window         dockForm
                    ?session        swin
                    ?side           'right)
        ); let
    The key parts are that I've taken out myForm and myForm2 from the let() in each function, and changed the callback to either do:
    or
    Either would be OK.
    In general top level user interface elements (e.g. forms, menus) must be in global variables. This is because the interactions with them must be accessible out of scope - particularly if they are non-blocking. There is no need for the form fields, or the dock window to be global.
    In your original popupform() function, it worked because the form was defined as being blocking - so the call to hiDisplayForm() meant that it was still within the scope of the popupform function. If you'd made the form non-blocking (as I've done in the modification above), or if the call to hiDisplayForm() had been outside of the function that created it, it also would not have worked. By ensuring the myForm and myForm2 are global - they are accessible everywhere. They also have to be global so that the CDS.log can record the updates to the form - so they are replayable.
    In the case of the dockform, it's always non-blocking - so you have to do this anyway.
    Provided you start from the global handle (or use hiGetCurrentForm()), you can retrieve the fields of anything on the form.
    Hope that helps!
    Oh, and I hope you're going to call the functions something more unique than dockform() and popupform() in reality. We recommend that functions are created using an uppercase prefix to avoid clashing with anything else - you'll have seen I use "ab" (but I work for Cadence); you might want to use something which is related to your initials (e.g. "RM" ) or your company name.
  • RushMehta
    Thanks for the quick fix. I have two issues with the code
    1) the new code works great for the first time. But if I run dockform again it throws following errors.
    dockform()
    t
    dockform()
    *WARNING* hiCreateForm: Could not delete already created form myForm2
    *WARNING* hiCreateDockWindow: formStruct@0x1714bc28 has been instantiated. Same form can not exist in more than one form or window.
    *Error* hiDockWindow: argument for keyword ?window should be a window type (type template = "wgsxg") - nil
    How do I handle the case where user opens two or more schematic window and docks the form there ?
    I thorugh of using dynamic name for form e.g concat("myForm" hiGetCurrentWindow()~>cellView~>cellName) but don't know how exactly it would work.
    2) hiGetCurrentForm() works with popup form but not the docked form. For docked form it always returns nil and causes error
      *Error* fprintf/sprintf: format spec. incompatible with data - "Format is 'Loading file from docked form %s ', argument #1 is nil"
    Rushang
    P.S. In my actual code I am using prefixes and upper case for the procedure names. This was just for demo code. :)
    Rushang,
    Apologies, you're right - you can't use hiGetCurrentForm() in a docked form. In my case it appeared to work because it actually referenced the popup form I'd created earlier.
    You will need to create a unique name for the form. Probably the best way is to use gensym (your case would fail if you opened two windows with the same cellName):
    formName=gensym('myForm)
    and then in the button's callback use:
         ?callback       sprintf(nil "printf(\"Loading file from docked form %%s\n\" %s->fileLocation->value)" formName)
    and in the hiCreateAppForm use:
         ?name formName
  • RushMehta
     Thanks for the info. I tried it out and workedperfectly. I am able to dock the form and interact with it correctly and also with multiple schematis and multiple docked forms in them.
    However I found one issue with docked form. They disapper when workspace of a session window changes. For example, after docking the form if user changes workspace from 'basic' to 'classic' or even if user descend down to a symbol view. Currently I have wrote a proc which is called when docked form's visibility changes. This proc simply undocks the form from the session window and thus the form is preserved. However if the form is already undocked, it disappears again :(
    This is not a big issue but it would be good if we can resolve it.
    Thanks again for your help,
    Rushang
