  3. Regarding ocean script
  • Subscribers 150
  • Views 15284
Arun Sinha
Arun Sinha over 14 years ago
Hello, I have created an ocean script file for parametric simulation using Analog environment in IC 5.10.41. When I restart the virtuoso and open the schematic and load the corresponding ocean script, it runs and shows the result. But when I update the component parameters, It doesn't show any change in simulation results. It repeats the same result evenif I put any value. It shows the changed results when analog environment runs and then script is loaded. It seems that any change in schematic is not passed to the script. from Arun sinha
    Probably because the saved OCEAN script uses:
    design("/path/to/netlist/netlist")
    and that is merely referencing an existing netlist. You'd have to use:
    design("libName" "cellName" "viewName")
    (and then make sure you load the OCEAN script in icfb, msfb, icms etc - not in the "ocean" executable, which doesn't have any netlisting capability in IC5141 (but does in IC61X)). If you do this it will incrementally renetlist, just as it would in ADE itself.
  • Arun Sinha
    Thanks Andrew, it works. From Arun sinha
