  3. skill to detect IC5
  • Subscribers 150
  • Views 15246
skill to detect IC5
ejm20
ejm20 over 14 years ago
My cdsinit has a few settings that can only work on IC6 so warnings are listed in the CIW.  Ive seen some code that will check the version in just a few lines but cant find any expamples.   Can you please point me to the article or provide some sample code.
    This is what I've used for the last 17 years:
    (procedure (abGetVersionNumber)
      (let ((parsed (parseString (getVersion))))
           /* in 4.4 onwards, version string is slightly different */
           (if (equal (caddr parsed) "version")
               (cadddr parsed)
               (caddr parsed)
    The other thing you might use (if it's database related) is dbGetDatabaseType() - that will tell you if you're running in a CDB (it returns "CDBA") or OpenAccess (it returns "OpenAccess") enabled version of the tool.
  • ejm20
    Hi Andrew - that does work but it returns alot of info, I only need to know if its IC5 or 6.  I did finally find 2 other solutions.   The if does not work and looks like its missing a  close ) but it does not go where I thought it should.
    if( rexMatchp("6.1" getVersion() then
       icVersion="61"
    else
       icVersion="51"
    ) ;if
    You can also make use of the database format. E.g.
    case( dbGetDatabaseType()
       ("CDBA" icVersion="51")
       ("OpenAccess" icVersion="61")
    ) ;case
    What do you mean it returns a lot of info? In IC5141, it returns "5.1.0" and in IC615 it returns "6.1.5" (6.1.4 returns "6.1.4"). That doesn't sound like a "lot of info". You could check if it's "5.1.0" and anything else could be assumed to be IC61 (assuming you're not running really old versions):
    inIC5141=(abGetVersionNumber()=="5.1.0")
    Then you have a flag to say whether you're in IC5141 and you can do:
    if(inIC5141 then
      ; do IC5141 related stuff
    else
      ; do IC61 related stuff
    In the first example you've posted, the missing parenthesis is before the then:
    if( rexMatchp("6.1" getVersion()) then
      icVersion="61"
    else
      icVersion="51"
    Fairly obvious if you look up rexMatchp in the documentation that it's a function accepting two arguments.
