  3. Error messages appears in my code
  • Subscribers 150
  • Views 15922
dell1
dell1 over 14 years ago
 For the attached ruler code there is two error messages appears
when I do the following :
  1. When I start marking the first point of the ruler without editing in the ruler options the following messsage appears in the icfb window:
    *Error* putprop: first arg must be either symbol, list, defstruct or user type - nil
    *Error* load: error while loading file - "*loadstring*"
  2. When I use the multi-segment option then I remove some points the following message appears in  the icfb window:
    *Error* CCSchangeCreateRulerFormPoints: too few arguments (2 expected, 0 given) - nil
    So could any one help me to fix that ?
    Thanks in advance.
half_ruler_v0p1.il
  • dmay
    dmay over 14 years ago
    You can run the following commands to get more details for an error:
    sstatus(stacktraceDump t)
    sstatus(stacktrace 10)
    sstatus(traceArgs t)
    With that said, you can see in #2 that the CCSchangeCreateRulerFormPoints is not being called with two arguments it expects. Looking at the enterLine command in CCScreateRuler, you can see that the delPointProc is defined to accept no arguments since the command is given with its parentheses. The addPointProc and doneProc are define to accept the arguments generated by enterLine. Remove the parentheses for the delPointProc and #2 will be fixed.
    Another problem witht he code is your first if statement is not defined correctly:
        if(boundp('CCScreateRulerForm) && CCScreateRulerForm then
          form = CCScreateRulerForm
          form = CCSmakeCreateRulerForm()
          else
        );if
    Notice that there is nothing happening in the else, and that form is defined twice in the if. Move the else between the form statements.
    I also found that hiGetCurrentForm() couldn't be relied upon to get the form id since multiple forms could be open and since the form can be hidden. To get the code to work for me, I made the form id a global variable and replaced all calls to hiGetCurrentForm() with the global variable name.
