  3. ccpCopy hang and crash
  • Views 15653
kb how
kb how over 14 years ago
I was trying to perfrom ccpCopy and end up with hang then crash.Below is the error message, does anyone have any idea what is the error message about. I try to figure out why, but failed.
\w *WARNING* (ccp) File is masquerading as a data directory!
Virtuoso version: IC6.1.4.500.6
 Thanks in advance.
  • skillUser
    skillUser over 14 years ago
    Hi How,
    Are you appending/prepending/changing the name of a file like the data.dm file (prop.xx if using IC5141) ?
    With only the message and the subversion I don't think there is sufficient information to really help out, can you submit a Service Request through Cadence Online Support?
    Lawrence.
  • kb how
    Hi Lawrence,
    Ya, i'm performing ccpCopy to copy from a cell to a new cell with new naming as well.
    The issue is fixed. The operation because there is few ambiguity files in the library, where gdm failed to handle it. I added additional check on top of the ccp to double check the file and cell before proceed.
     Thanks Lawrence.
