  3. Plot waveforms with Ocean
  • Subscribers 150
  • Views 17522
Aldo2
Aldo2 over 14 years ago
I want to save a waveform as a png file in an Ocean script. I use the following code:
ocnWaveformTool('wavescan)
plot(v("/OUT" ?result "tran"))
hardCopyOptions(?hcOutputFile strcat(plotTitle ".png"))
hardCopy()
where plotTitle is a variable depending from an index.
Each time a new plot is generated, Linux changes my desktop, going to the workspace containing the terminal I used to launch the Ocean script. Is there a way to avoid it?
    This may be a function of the window manager you're using - or maybe the Cadence IC version you're using. I'm using KDE  3.5.4 and do not see this with IC614 or IC615.
  • Aldo2
    I use IC5141 and KDE 3.3.1.
    Is there a workaround to save a plot without opening a window?
    Thank you
    Aldo
    Aldo,
    If you run "icfb -nograph" or "ocean -nograph" no windows will be opened (they'll go to an invisible X display).
  • Aldo2
    Thank you Andrew, your solution solves my problem!
    Regards
    Aldo
