  3. copmpare variable to string
  • Subscribers 150
  • Views 16568
ForcedToWork
ForcedToWork over 14 years ago
Very new at this... I'm trying to grab the layer purpose and compare it to a fixed string.  Here's a dumbed down version.  I can't find a way to compare the two even though lp returns ("drawing")
lp= geGetSelSet()~>purpose
 cond(
 (lp=="drawing" print("OK"))
 (lp=="pin" print("BAD"))
);cond
This returns nil
  • skillUser
    skillUser over 14 years ago
    You are so close!  The problem is that geGetSelSet() returns a list of objects, but you are comparing the result as just one string as opposed to a list that contains a string.  The solution is modify the first line, something like this:
    lp= car(geGetSelSet())~>purpose
    This way you grab the first object on the list.  If you need to do this for multiple selected objects, then introduce a foreach loop or some other way to process multiple results (e.g. forall() ).
    Hope this helps!
    Lawrence.
  • ForcedToWork
     Thanks!!!  With a few more attempts I got the base lines working.  The "forall" loop worked, now just some clean up.  Thanks again, appreciate the help.
