  3. how to add component parameters list in hiCreateCyclicField...
  • Subscribers 150
  • Views 16771
how to add component parameters list in hiCreateCyclicField ?choices
yuhua
yuhua over 14 years ago
Hi all ,
i want to add skill code when i select library name , add cell list in  CellName
when i select cell name , add component parameters list in CellParamName
library and cell name select is ok , but i could get component parameters list when i select cell name .
pls help it , thanks
                     list(
                          hiCreateCyclicField(?name  'LibName
                                              ?prompt "Library Name :"
                                              ?choices libNameList
                                              ?defValue "analogLib"
                                              ?callback "cellNameList=ddGetObj(LibForm->LibName->value)->cells~>name
                                                         LibForm->CellName->choices = cellNameList"
                          (0:35) (600:30) 200
                     list(
                          hiCreateCyclicField(?name  'CellName
                                              ?prompt "Cell Name :"
                                              ?choices cellNameList
                                              ?callback "cellParameterList=cdfGetCellCDF(LibForm->CellName->value)->parameters~>name
                                                         LibForm->CellParamName->choices = cellParameterList"
                          (0:70) (600:30) 200
                     list(
                          hiCreateCyclicField(?name  'CellParamName
                                              ?prompt "Component Parameters :"
                                              ?choices cellParameterList
                          (0:105) (600:30) 200
    Your question is not that clear. What doesn't work? A complete example would help otherwise people have to spend significant time adding the missing parts to try it out to find out what the problem is.
  • yuhua
    Dear andrew ,
    My question is how to add component parameters to list , when i select cell name , thanks
     cdfparam.il , load("cdfparam.il") in CIW
    procedure(LibForm()
       let((libNameList cellNameList cellParameterList LibForm)
           libNameList = ddGetLibList()~>name
           cellNameList = list(" ")
           cellParameterList = list(" ")
           fields = list(
                         list(
                              (0:35) (600:30) 150
                         list(
                                                  ?callback "cellParameterList=cdfGetCellCDF(LibForm->CellName->value)~>parameters~>name
                              (0:70) (600:30) 150
                         list(
                              (0:105) (600:30) 150
                        ) ; end of first list
           LibForm = hiCreateAppForm(?name 'LibForm
                                     ?fields fields
                                     ?formTitle "parameter select"
                                     ?callback "Run(LibForm->libName->value
                                                    LibForm->CellParamName->value
           hiDisplayForm(LibForm)
          ) ; end of let
    ) ; end of procedure
    LibForm()
    The value passed to cdfGetCellCDF was wrong. You need to pass it a dd object. It should be:
                                                  ?callback "cellParameterList=cdfGetCellCDF(ddGetObj(LibForm->LibName->value LibForm->CellName->value))~>parameters~>name
                              (0:70) (600:30) 150
  • yuhua
    Dear andrew,
     it's work now , thanks for your help
    BRs,
    Yuhua
