  3. Run Skill Scripts and Update Schematics from Unix Command...
  • Replies 9
  • Views 24383
Run Skill Scripts and Update Schematics from Unix Command Line
skillseeker
skillseeker over 15 years ago
Can we load and run skill procedures without having to invoke interactive command window. I have started to read about "interprocess communication" but it looks like these need to be run from the CIW window.
  • Prism
    Prism over 15 years ago
    hi,
    Yes, IPC commands are for running linux commands from an icfb/virtuoso session.
    To run skill code in batch mode, you could do:
              icfb -nograph  -replay MYSKILL.il -log MYBATCH.log
    to run skill in batch mode.
    good luck!
    /Nani
  • skillUser
    skillUser over 15 years ago
    In addition to what Nani said you may also be able to run the executable "dbAccess" which is a non-graphical executable which contains core SKILL functions plus functions that could be run inside of a Pcell, these include db* prefix functions, dd* functions, rod* functions and tech* functions.  No graphical capabilities exist at all within dbAccess, so functions like hi* or ge* will not work, and the application SKILL API's are not present either, so no sch* or le*.  Having said this, it is a useful tool for performing core SKILL functionality or testing PCells to ensure that they would run in other environments (e.g. for Stream Out use). This executable is not officially documented yet, but this is coming soon.
    Best regards,
    Lawrence.
  • skillUser
    Oh, I forgot to mention, ipc* functions are implemented dbAccess.
    Lawrence.
  • jorenrefuerzo
    jorenrefuerzo over 13 years ago
    "Can we load and run skill procedures without having to invoke interactive command window. I have started to read about "interprocess communication" but it looks like these need to be run from the CIW window."
     Hi, I also have the same promblem, i want to run Skill Procedures without opening virtuoso or CIW. and just run it in command line...
    I did not understand clearly the replies coz it seems to me that the replies are for "running unix commands from virtuoso or skill script"
     Please reply...
     You're right. This post has nothing to do with what you're trying to do (and you've asked that elsewhere in the forum).
  • ahmaddaiict
    ahmaddaiict over 11 years ago
    Hello I try to run the below given command
    virtuoso -nograph -replay ../RO/INV42/SKILL/INV42.il -log  MYBATCH.log
    However the error is the following:
    A VNC server is already running as :80 or another process is using one of ports 5980 or 6080
    *WARNING* Unable to open -nograph X Window Display "xxxx:80"
    *WARNING* (using "exec /yyyy/software/cadence/release2013/ic_v6.16.022/tools.lnx86/dfII/../bin/cdsVncserver :80 -co /usr/share/X11/rgb&").
    *WARNING* cdsXvnc output may be found in file $HOME/.vnc-cds/xxxx:80.log
    Trying another display...
    A VNC server is already running as :81 or another process is using one of ports 5981 or 6081
    *WARNING* Unable to open -nograph X Window Display "xxxx:81"
    *WARNING* (using "exec /yyyy/software/cadence/release2013/ic_v6.16.022/tools.lnx86/dfII/../bin/cdsVncserver :81 -co /usr/share/X11/rgb&").
    *WARNING* cdsXvnc output may be found in file $HOME/.vnc-cds/xxxx:81.log
    A VNC server is already running as :82 or another process is using one of ports 5982 or 6082
    *WARNING* Unable to open -nograph X Window Display "xxxxx:82"
    *WARNING* (using "exec /yyyy/software/cadence/release2013/ic_v6.16.022/tools.lnx86/dfII/../bin/cdsVncserver :82 -co /usr/share/X11/rgb&").
    *WARNING* cdsXvnc output may be found in file $HOME/.vnc-cds/xxxx:82.log
    A VNC server is already running as :83 or another process is using one of ports 5983 or 6083
    *WARNING* Unable to open -nograph X Window Display "xxxx:83"
    *WARNING* (using "exec /yyyy/software/cadence/release2013/ic_v6.16.022/tools.lnx86/dfII/../bin/cdsVncserver :83 -co /usr/share/X11/rgb&").
    *WARNING* cdsXvnc output may be found in file $HOME/.vnc-cds/xxxx:83.log
    Successfully connected to a non-graphical X Window Display server.
    The skill file must generate a layout pcell. I cannot generate it when i execute the -nograph command from command line but i can generate the layout, if i load the skill file in CIW window.
    Please guide me with the debugging pointers
    Ahmad.
  • skillUser
    skillUser over 11 years ago
    Hi Ahmad,
    Those were Warnings not Errors, and anyway, I see the following message at the end of the section you posted:
    I suspect that the PCell issue is due to something else - where is the error relating to being unable to generate the PCell?  Have you run the SKILL Lint tool on your code to scan for possible issues? (Access it from Tools -> SKILL Development environment when using IC61x/ICADV12x ).
    If the -nograph really is the source of the issue, did you try taking a look at the log files?  The documentation notes the following:
    Note: cdsXvnc can leave locked files in /tmp if it exits abnormally (for example, it is killed or crashes). In such cases you may be displayed warning messages like:
    *WARNING* Could not open display sfsol804:80. If no X server is running for
    *WARNING* this display, please remove the file /tmp/.X11-unix/X80.
    Also you could try -nographN where N is 0-9 to see if that helps.  Post back with your efforts and results...
    Good luck!
    Lawrence.
  • ahmaddaiict
    Hello Lawrence,
      Thank you very much for your prompt response. The error is form myside in environment setup.
      virtuoso -nograph1 -replay ../RO/INV42/SKILL/INV42.il -log MYBATCH.log is working perfectly.
    I also need a help:
    Is there any command which can generate a gds file from a script file.....I need to use this command in a script .
    Thanks & Regards
    Ahmad
    The UNIX command "strmout" can be used. Try invoking it without any arguments to see the help for it.
