  3. Error in addvia code
  • Views 15135
brittooo
brittooo over 14 years ago
 Hi
I would really appreciate if you could take a look at my code copied below and let me know the reasons for the 2 bugs mentioned:
;PROCEDURE TO ADD VIA1,VIA2,TV AT THE DESIRED POINT IN THE LAYOUT
;AUTHOR:SwK
;CREATED:8 SEP 2011
;BUG1: does not work unless the contact form is opened atleast once after the
;cadence is initiated.
;BUG2: Via1/Via2 are sometimes placed with TV dimensions
procedure(addVia(var)
       let((cv tid via1W via1S via2W via2S tvW tvS )
       cv=geGetWindowCellView()
       tid=techGetTechFile(cv)
       via1W=techGetSpacingRule(tid "minWidth" "Via1")
       via1S=techGetSpacingRule(tid "minSpacing" "Via1")
       via2W=techGetSpacingRule(tid "minWidth" "Via2")
       via2S=techGetSpacingRule(tid "minSpacing" "Via2")
       tvW=techGetSpacingRule(tid "minWidth" "TV")
       tvS=techGetSpacingRule(tid "minSpacing" "TV")
        unless(boundp('leOcontactForm)
        le0ContactForm->contactType->value = var
        hiRegTimer("cancelEnterFun(le0ContactForm)" 1)
        leHiCreateContact()
        );unless ends
  if(var=="M2_M1"
    then leCreateContact(cv var hiGetPoint(hiGetCurrentWindow()) "R0" via1W via1W 2 1  via1S via1S "center" "center")
    );if ends
  if(var=="M3_M2"
    then leCreateContact(cv var hiGetPoint(hiGetCurrentWindow()) "R0" via2W via2W 2 1  via2S via2S "center" "center")
     );if ends
   if(var=="TM_M3"
      then leCreateContact(cv var hiGetPoint(hiGetCurrentWindow()) "R0" tvW tvW 2 1  tvS tvS "center" "center")
     );if ends
       );let ends
       );EOP
;BINDKEYS FOR CALLING THE PROCEDURE:
;hiSetBindKey("Layout" "Alt<Key>z" "addVia(\"M2_M1\")")
;hiSetBindKey("Layout" "Alt<Key>x" "addVia(\"M3_M2\")")
;hiSetBindKey("Layout" "Alt<Key>c" "addVia(\"TM_M3\")")
Also whenever a wrong dimension via is placed, the following 3 lines appear in the CIW :
*WARNING* techGetTechLibName: argument must be dbCellViewId or techFileId or ddId for cell, library, etc - nil
*WARNING* ddGetObj: invalid libId ((nil)).
*Error* _leIsContactCdsVia: argument #1 should be a database object (type template = "dt") - nil
Regards
Brittoo
    Brittoo,
    First of all, this bit of code doesn't add any value, and is probably the cause of the first bug:
            leHiCreateContact()
            );unless ends
    I removed it, and the code places vias OK. There's no need to invoke the form when you're using the non-UI leCreateContact function. However, you're passing the wrong values to leCreateContact for the "pitch" parameters. Currently you're passing the spacing, rather than the pitch. You should be having:
       if(var=="M2_M1"
        then leCreateContact(cv var hiGetPoint(hiGetCurrentWindow()) "R0" via1W via1W 2 1  via1S+via1W via1S+via1W "center" "center")
        );if ends
      if(var=="M3_M2"
        then leCreateContact(cv var hiGetPoint(hiGetCurrentWindow()) "R0" via2W via2W 2 1  via2S+via2W via2S+via2W "center" "center")
         );if ends
       if(var=="TM_M3"
          then leCreateContact(cv var hiGetPoint(hiGetCurrentWindow()) "R0" tvW tvW 2 1  tvS+tvW tvS+tvW "center" "center")
         );if ends
  • brittooo
    Hello Andrew
     Thanks for looking into the code. I reran the script after making the changes suggested by you. However, now the vias placed by calling the addVia() function retain the values of the last placed via. For e.g. if a TV was placed before placing a Via2/Via3, then the via2/via3 would be placed with the dimensions of the TV. Same happens the other way around when a via2/via3 was placed before the TV.
    Inspite of this bug, the variables assigned to minWidth,pitch show the correct values in the CIW.
    Is there a way to fix this bug ?
     FYI, I am working on IC5141.
    Thanks in advance,
    Brittoo
