  3. How to check if a variable exists (has been defined already...
  • Subscribers 150
  • Views 17948
How to check if a variable exists (has been defined already)?
swdesigner
swdesigner over 14 years ago
Searched the forum, couldn't find an answer.
In perl, one can do defined(var_name). Is there a way in skill?
Ultimate goal, I want a single bindkey (say CTRL-g) to toggle the grid in my AWD window. Since there is no function (that I know) to find out if the grid currently exists in this window, the only way I can do this is set a var to t the very first time I hit my bindkey and then keep using it to get the status and keep toggling it.
But, for this, I need to know if the variable has been defined already.
Thanks!
  • eDave
    eDave over 14 years ago
    boundp eg boundp('my_var)
  • swdesigner
    Thank you!
