  3. Use PRIMLIB with variable
  • Subscribers 150
  • Views 15565
Telekito
Telekito over 14 years ago
 I need to use the library PRIMLIB with variables, i try to use desvar, but as, ps, etc.. are wrong because have a numeric valor.
How I can use PRIMLIB with variables?
thanks in advance and sorry for my english.
    Without knowing who supplied "PRIMLIB", and knowing the details of how it is implemented, it's hard to answer this. The question would be better if you had given who supplied it - i.e. which design kit it is part of - together with other information as suggested in the Forum Guidelines.
    In practice this would be best asked to the supplier of the library. Quite likely they have CDF callbacks which prevent the use of variables - and this is unfortunately bad design on the part of the library and there's little you can do about it. There's some discussion on this in my note on the Dangers of CDF Callbacks.
