  3. yLimit doesn't work with awvPlotWaveform() if stripNumber...
  • Subscribers 150
  • Views 1112
yLimit doesn't work with awvPlotWaveform() if stripNumber is set
markbeck
markbeck over 14 years ago
Greetings all,
Using version IC6.1.5.500.1
If I execute the following in the CIW,
  • newWindow()
  • awvPlotWaveform(awvGetCurrentWindow() (list <waveform>) )
  • yLimit((list 1 2))
yLimit works fine.
But if I type the following in the CIW:
  • newWindow()
  • awvPlotWaveform(awvGetCurrentWindow() (list <waveform>) ?stripNumber (list 1))
The yLimit fails with the message:
This command requires a valid object id.  No object with the id "" could be found.
No graph object selected.
nil
If I don't use awvPlotWaveform and  execute the following:
  • newWindow()
  • plot(<waveform> ?strip 1)
 The yLimit command works fine.
If I use the awvSetYLimit command, it works fine.
  • newWindow()
  • awvSetYLimit(awvGetCurrentWindow() 1 (list 1 2) ?stripNumber 1)
 Has anyone else encountered this issue?
Mark
  • markbeck
     Sigh.... posted too fast.  If I'm running Ic6.1.5.500.5, the problem goes away.
    It appears to have been fixed.
    Mark
