  3. Question About Layers Palette
  • Subscribers 150
  • Views 16172
jazzmatazz
jazzmatazz over 14 years ago
Hi everyone, so the problem is this. I use this code to set bindkey (for Virtuoso IC61) "_pteHiLayerSetActiveLpp(dwindow('pteLayrePalete1) "some layer") " work but only for Palette1 ,when open 2nd layout window it doesn't work because number of the palette is other. How can to resolve this problem ,any ideas? Regards , NK
    A similar question came up on the Custom IC Design Forum recently. As you'll see in my reply there, you should be using leSetEntryLayer, not the palette function.
  • jazzmatazz
    Now everything is OK Thanks Andrew
