  3. Inductor Layout
  • Views 18033
Inductor Layout
kalikrishna
kalikrishna over 14 years ago
 Hai all
I want to draw Inductor using Cadence Virtuoso 6.1.4 version.
If anyone know please do let me know..
  • Quek
    Quek over 14 years ago
    Hi kalikrishna
    You can use VeloceRF from Helic to generate a good inductor. The generation process involves EM simulation so you can be sure that you are getting a very good inductor. It is certainly possibly to draw an inductor using Virtuoso Layout Editor but it would not be possible to obtain an accurate inductance value. A 3rd option would be to use the inductors that come with your PDK.
    Best regards
    Quek
  • LorentzTS
    LorentzTS over 14 years ago
    Another option is to use PeakView from Lorentz Solution. It can generate inductors for you using parameters you provide. It will output an s-param or a RLC model for Spectre or SPICE. It is fully integrated with Virtuoso so you get all the cellviews right in your library, and uses a full wave EM-solver.
    It can also give you accurate simulation models for any hand drawn geometry.
    www.lorentzsolution.com
    -Tom
