  3. Custom netlisting procedure
  • Subscribers 150
  • Views 17007
jmss
jmss over 14 years ago
I am trying to customize the netlist procedure for hspice.
In the hspice view I configured these properties:
  • hnlHspiceFormatInst = dummy()
  • hnlHspiceParamList = hnlHspiceMOSfetParamList
Then I wrote dummy() like this:
procedure(dummy()
printf("Custom netlisting procedure...\n")
inst = hnlCurrentInst
print(inst->??)
formatter = nlGetFormatter(inst)
;nlPrintInstName(formatter, inst)
When I run netlisting with:
  1. simInitEnvWithArgs(runDir libName cellName viewName "hspice" t)
  2. simReNetlistAll = 't
  3. simNetlistHier = 't
  4. netlist()
I get this error:
Running netlist
Begin Incremental Netlisting Sep 23 18:22:53 2011
(db:0x151eca14 cellView db:0x151ecd12 objType "inst" prop nil bBox ((-1.925 -1.8625) (-0.725 -1.25)) children nil groupMembers nil isAnyInst t isShape nil matchPoints nil net nil parent nil pin nil purpose "cell" textDisplays nil assocTextDisplays nil markers nil figGroup nil baseName "MN1" cellName "nmos_dummy" instHeader db:0x151ec612 instTerms (db:0x151ec11c db:0x151ec11b db:0x151ec11a db:0x151ec119) libName "devLib" master db:0x151edd92 name "MN1" numInst 1 viewName "symbol" conns (db:0x151ec11c db:0x151ec11b db:0x151ec11a db:0x151ec119) mag 1.0 orient "R0" status nil transform ((-1.5 -1.5) "R0" 1.0) xy (-1.5 -1.5) cluster nil blockages nil physOnly nil source "netlist")
*Error* (Default-reader-method) generic:nlGetFormatter class:dbobject
End netlisting Sep 23 17:47:44 2011
I can't find anything on this error. Is it related to mixing nl and hnl functions?
Any help would be appreciated.
Best regards,
João M. S. Silva
    The nl functions are for the "direct" netlisters, as used in ADE. So that would be where the netlister is hspiceD. The hspice netlister is a traditional hnl netlister.
    So you are mixing in the nl functions in an hnl netlister, and that doesn't make sense.
  • jmss
     Thanks.
     Can you show the skeleton for an hnl-based netlister?
    João M. S. Silva
    Hi Joao,
    I don't have one to hand (I don't tend to see too many questions about the hspice rather than hspiceD netlister). Best thing is to log a service request for this.
  • jmss
     Thanks, I've created an SR.
     Just one more question: is that because hspice will be dropped and hspiceD is to be made the one official netlisting method?
     Regards.
     João M. S. Silva
    No, there are no plans to drop hspice in favour of hspiceD. They're just different interfaces (one from schematic, not CDF based, and the other from ADE and is CDF-based).
