  3. Change layers automatically with an skill function
  • Replies 9
  • Subscribers 150
  • Views 23085
MariaOtz
MariaOtz over 14 years ago
I am trying to find a skill function that can change the layer of any shape of the layout from one layer to another. For example: all the shapes that are with M1 in the layout change them to M2, all the shapes that are in M2 change them to M3...
I need to do this for many different layers.
Can someone help me with this?
Thank you in advance
  • MariaOtz
     Right now I am using Find/Replace function manually and is working but when I need to change many layers then it is not very nice to do it in this way.
    cv=geGetEditCellView()
    LP=car(exists(lpp cv~>lpps LP~>layerName=="M2" && LP~>purpose="drawing"))
    LP~>shapes~>layerName="M3"
    Of course, you'll need to do it in the right order (don't do M1 to M2, then M2 to M3 because all the M1 will also end up on M3).
  • MariaOtz
     Hello Andrew,
    Thank you very much for your quick response.
    I tryed what you said but I get a warning: illegal left hand side of the assignment operator.
    It does not do the conversion properly because I have some layers that have not been change. Can this be because I have some guardrings that have metal 1 inside. This script does not work with the ROD multipart paths?
    THank you very much
    Maria
    Sorry, I typed it too quickly (I didn't test it) and made some typos - so here's a correction:
    LP=car(exists(lpp cv~>lpps lpp~>layerName=="M2" && lpp~>purpose=="drawing"))
    As for ROD objects (multi-part paths), if the shapes is a subShape of the ROD object, then it will not change layer if you try - you'd have to "unname" the ROD object before changing it. Cadence Online Support Solution 11157752 gives some tips on this.
  • MariaOtz
     Thank you again. It is working now :-)
    I will take a look at the problem with the RODs now
    BR
    Maria
  • MariaOtz
    Hello Andrew,
    Sorry for bothering you again. But in case I want to make this script work through all the hierarchy what function do I need to use?
    I tried with the leSearchHierarchy but it doesn´t work.
    THank you very much,
    Maria
  • MariaOtz
    Does anyone know how to run the script through all the hierarchy?
    I am still trying to find a solution for this. I tried different things but I didn't make it work.
    Thank you,
    Maria
    Hi Maria,
    Something along these lines:
    procedure(MYtraverseHier(cvId @optional (done makeTable('cellViewsDone nil)))
      ; do whatever change you want here - e.g. layer change
      ; now traverse the hierarchy
      foreach(master cvId~>instanceMasters
          ; filter out anything done before, or pcell instances
          ; could extend this condition to filter out certain libraries - do what you want
          unless(done[master] || master~>superMaster
            done[master]=t
            MYtraverseHier(master done)
    This is not tested, but it's a fairly standard recursive hierarchy traversal.
  • MariaOtz
    Thank you very much Andrew.
    It works fine :-)
    Br,
    Maria
